Why how much you pay for yours?
Erm 3200 with tyres. Its a pretty good price too but I dont mind pay a few hundreds more for a set of newer rims. My import cals tells me that TE37 are around 3.5k excluding EMS. Which is still very cheap!!!
It's easy as buying shit off yahoo. You need to use a broker as you cant just bid if you dont have a Jap bank account however. There are loads of brokers, all charge around the same.
www.importmonster.com.au is one, there are a couple of small timer people on secret drift who are cheaper, but things may take longer as it's just a sideline business (Aussies living over there just earning some extra bucks).
Just do some re search and see who people have used.
Spoken to streeter and he seems like a genuine bloke. Only downside is he uses ONLY email but he reply very quickly (cant comment any further as I didnt end up buying anything from him).
Depends how deep the holes in the 25mm spacer are...
Heres the ones i got http://cgi.ebay.com/ws/eBayISAPI.dll?ViewI...em=360168445193
Dont know how long my studs are ill find out when im home.
i been busy azzzzzz bishes!!
see you guys tonight
tristan pussying out again?? lol muahaha *raises the pinki* your new name shall be, -Astro the pinki raiser!
got ur hubs ready....
seeya all tonight.
awwwwoooorrrsum...
Taco is here with me, brandon pussed out, geoff pussed out, tristan well.. he pussed out.
collin should be in!
should be alright turn out,
bitches were all scared of me bringing my car out.. :thumbsup:
    • This. The R34 handbrake icon DOES come up when the brake fluid level is low. You might be sitting right on that threshhold. I have been down this diagnosis path and this was the solution (and it was pretty much as full as your picture is to begin with).
    • Unfortunately the cavaet to that is that while any scan tool should be able to read the code, the workshop will need a consult plug to OBD socket adapter. You don't have a location on your profile, where are you based?
    • @Haggerty this is your red flag. In MAP based ECU's the Manifold pressure X RPM calculation is how the engine knows it is actually...running/going through ANY load. You are confusing the term 'base map' with your base VE/Fuel table. When most people say 'base map' they mean the stock entire tune shipped with the ECU, hopefully aimed at a specific car/setup to use as a base for beginning to tune your specific car. Haltech has a lot of documentation (or at least they used to, I expect it to be better now). Read it voraciously.
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
