Astro's mums gold.
She loves it.
she'd love it more if it lasted more than 10seconds - she keeps on complaining about it
ugh, poor lass
ugh, poor lass
anymore and she would be loose as my HKS super dragger cannon..
lol she needs a service! major one at that! stat!
Are the HKS super dragger's any good ? My r33 came with it already. I was curious if its good ?
Wooo wooo just ordered some Split fire's of eBay and gettin in contact with plazmaman about a new plenum and 72mm throttle body
Edited by Danski
yeah mate there good quality exhaust, mild steel tho, so she wont last as long as stainless. but by the time it craps out your car will be rooted.
sounds good, should hitup PCE for parts, rather then ebay. as for plenum, stock one is good for up to 400kw or something.
Sweet. Thanks.
Wats PCE?
And yeah i know i dont really need a plenum but it will be a bit of a power increase and it get rid of the horrible looking standard one.
What do you do atm?
I work in water. I'm a water treatment plant operator by trade and at the moment I work as a controller looking after all of brisbane's water (25 reservoirs) and sewerage pumping stations (314). As well as a few treatment plant's.
What do you do ?
What do you do ?
Wow that sounds cool.
Im a mine surveyor - Not qualified but just about to start study.
Work wants to pay for it so ide be stupid not to :)
Its not bad. Always wanted to get out into the mines. I've got my HR licence too. Is it hard to get into the mine work ?
    • Resizing injectors in Nistune can be done a couple of ways, and there are a couple of ways that you can make a mess of it. The tuner needs to be really aware of the effects of whichever approach he uses (either K, or TIM). They are both easy enough to "get the injector size right" to run the engine. But little details like old start enrichment and hot start are affected differently, depending on which boxes you check.
    • Pretty safe to say almost everyone that has tuned their own car has experienced this issue. The difference being that we have our laptop in the car and when it happens, it's literally 10 seconds of tuning to sort it.  Would you be happy to plug in your laptop and sort this yourself? It is a very simple process and there is no risk of harming your engine (if you are worried about that).
    • Yeah thats the next step now, either they wil or i will take out for a drive to work and go straight their after work and see is we get the same issues 🤞  thought i try my luck here too, never know someone else might have had the same issue but thanks for the reply
    • Basically your tuner needs to drive it for the 30 min (or whatever) to create the same conditions then check the ECU settings and sensors at that time. They may not be excited to because that takes them 30 min rather than just opening the bonnet and seeing the problem straight away.... Hot start is generally not as tricky as cold start, but there would be a table for fuel enrichment vs coolant temp as a starting point
    • Yeah, they all cant say anything for sure as everything is working fine . Said unable to find an issue untill it stops again. Could mist likely be CAS wiring or IAS valve issue but again not 100%
