tristan's hair pulls bitches :rofl:
hahha what now?!
Neither of these bitches are doing it right. Faild scene queens from rosies come to mind. Tell the one of the left to use some hair spray, please!
BITTTTCHHHHHHEZZZZZZZZZZZZZZZZZZZ :blink:
clearly into boys...
biggest lie. all i saw / heard was granny shifting and lack of limiter love.
Tell me if the lines onto Pullenvale Rd are half decent. There was plently of smoke but these tires seem to smoke better then the marks they leave.
ahha ill check in the morn, however i would of hurd it.
lol wow pics look nice colin farken hawt..
suits your car right nice!!
as for tristian all those girls in the photo are whores with crabs anbd dangle berries
i slept the arvo sleeping and catching up on rest... the 180 is going on the hoist tommorrow
fuel pump should arrive as well as the lines..
News!: I found my annoying f**king boost leak.. the rubber air in take pipe had a f**king huge crack in it AFM side but underneath so i couldnt see it farking pain in the ass.. so now gonna do a very noice custom intake pipe and shit :blink:
News!: I found my annoying f**king boost leak.. the rubber air in take pipe had a f**king huge crack in it AFM side but underneath so i couldnt see it farking pain in the ass.. so now gonna do a very noice custom intake pipe and shit :D
very noice ill be there to hit it together too bro.. just have finish puttin the kit on my car so i can rego it on tue :)
looks like they are both hittin the road at bout the same time :blink:
    • Messing around with. Twin kit for. Rb30/26
    • For fuelling the Haltechs have O2WB fuel controllers. Very useful for helping tuning VE and correcting for *small* mistakes. Of course if your injector/cam/trigger/sensor data is just wrong (or for a GTT which is not a GT) then you will get impossible reactions to things. I am sure you know this already but the reason people don't typically put haltechs (or any Aftermarket ECU) on GT's is because there's practically no real gains to be had - So this knowledge won't be commonplace.
    • Can someone tell me if the cracks seen in the rear sway bar bushings in these photo's is unacceptable from a roadworthy point of view?
    • Shouldn't need a "base map" for anything other than guidance to ignition tuning. You just need the engine capacity right, the injector size right, and something, almost anything, for a VE map. On an NA engine, fuelling is almost completely a function of load signal & rpm. It should run and drive with a completely flat fuel map. It will be too lean under load, but that's easily fixed. We used to tune all ECUs without any base map. There were no such things (until someone had tuned a near stock engine on one, and then they had a "base map".
    • What did you actually buy/how much did it cost? When I got mine in like.. 2017...? 2019? the aim was to run Torque for gauges via ODB2 and things like Track Addict/Laptimers/Dashcam/Reversecam/Spotify etc. Mine never broke, but I wonder if you've got the same needs (it sounds like it). Cause I liked the idea of being able to do anything with it. That said, yours also cost 3x the cost of what I spent so... food for thought.
