a valid point..
tehehe
im in a lecture now - this chick is craaazy tehe
she has the document camera happening, and her nails are like 5cm long - epicc!
So are you an Astroboy or Astrogirl. Hmm, might message the Japanese for a new spin on cartoons. Maybe an epic fail.
that post failed.
Are they real nails, or glue ons. Gees, one of those up your butt will test friendship.
that post also failed.
happen before while doing your spray tan? lol
:D
tehe this never gets old -->
ps dan,
what happened with that gold coast post of yours??
OMG it got shut down faster than a speeding bullet :(
Col said to use whoretown..........not sure why :huh:
I think Taz put him up to it :P just to see me fail - lol
Edited by Danski
hey breh,
coming skylining this sunday?
Maybe, t-belt tensioner was done up too tight after I had the water pump changed, sounds so ghey... lol. Whine whine whine... Plus im going out Sat night.
You going?
yehh man i think ill head out :P
yeh i think old tasman did mine up a little tight, it gets angry every now and then wen i turn her on
IIRC it's a spring loaded bracket, so if the bracket is a bit tired they'll whine, as they tend to get done up too tight. Meh, no biggy. My car sounds like it has a super charger.
skids :huh:
Big thanks to Dave for hooking me up with kakimoto system :D:D:cool:
no worries man, was hoping to get it bit cheaper tho. :D
Regu06? I wanna hear how quiet is that. Hopefully there 1 tomorrow!
you'll have to wait for my car to be up and running to hear it. :D
___
astro see ya tmoz morn around 7:50 ready for charity cruise
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
