well couldnt get the kaki system to line up with my current dump + front after much f**king around so i put the old one back on. Then i saw that i appear to have an oil leak :( so no cruise for me today :P
well couldnt get the kaki system to line up with my current dump + front after much f**king around so i put the old one back on. Then i saw that i appear to have an oil leak :devil: so no cruise for me today :(
Oh man that sucks, hope its nothing serious
Shit. Thats no good. Was the right part order or whats the hiccup?
My existing exhaust is custom so i didnt really expect it to line up, but after laying out out beside the car it looked like it would work. But front pipe is a couple of inches short :thumbsup:
front pipe is a couple of inches short :)
that's what she said
so today on the cruise, I went with Admiral Joe. Here's a couplea pics.
This fool got us lost because apparently TURN RIGHT, mean turn left. :D
If that stupid 4x4 hadn't been there, we would have had two 32s bordered by two 33s
Approaching vessel off the starboard bow Admiral!
Then at the end, there was free sex
<3
did joe decide to fire the cannons!?
he was trying to catch up to the other boat in front of the 4x4 lol
ps the pce stickers on the 2 32s look seck-ceeeee :D
ps the pce stickers on the 2 32s look seck-ceeeee :)
fk yea!
should see my crv.. :D
see brandon, joe and others!
man up! u know u want too
    • This. The R34 handbrake icon DOES come up when the brake fluid level is low. You might be sitting right on that threshhold. I have been down this diagnosis path and this was the solution (and it was pretty much as full as your picture is to begin with).
    • Unfortunately the cavaet to that is that while any scan tool should be able to read the code, the workshop will need a consult plug to OBD socket adapter. You don't have a location on your profile, where are you based?
    • @Haggerty this is your red flag. In MAP based ECU's the Manifold pressure X RPM calculation is how the engine knows it is actually...running/going through ANY load. You are confusing the term 'base map' with your base VE/Fuel table. When most people say 'base map' they mean the stock entire tune shipped with the ECU, hopefully aimed at a specific car/setup to use as a base for beginning to tune your specific car. Haltech has a lot of documentation (or at least they used to, I expect it to be better now). Read it voraciously.
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
