three words post
sheer brilliance - once again - mick for pm? :P
would if be worth it if i came down thursday night from sc :D
if hot 15 year olds with icecream is your thing then defs :D
get back to work nig! Uni is fail. that is all
totally - im in the 24hour computer lab doing a group assignment
fml
becareful mick his looking for a reason to go down on you mick!
dw i have plenty of time to cup aswell tasman
(deletes false aligations)
tris if i make president, ill make gay marriage constitutional. just 4 u :D
sounds delicious
because we believe in the love that exists between two vaginas,
the most important kind of love, is the love that exists between two naked women while i watch :P
Edited by astrotristan2
the most important kind of love, is the love that exists between two naked women while i watch :D
I saw two females make out at a club I was at on the weekend. Swear to god, I was all giggles.
haha i own your novice sight, tristan can confirm.
if only i had access to my on board camera. was at schoolies back in the day.
involved me / mates watchin and 2 drunk chix in there hotel room.
lets just say one squirts...
    • It's almost certainly a reluctor generating an "AC" waveform. No, ECUs don't generally read those - they're usually set up for PWM square wave 0-5v stuff.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
