Nah all good man I gotta trade the guy that i bought them from for some others that hes got.
Just gota find something that I like and that fits my car better :D
I think anything more than 9 on gtt/gtst will scrub unless you do mods to it. From memory, the offset you've got are for GTRs... who are you getting it from anyway? What sorta rims are you looking at?
Im getting them from J-Imports.
Yeah the ones that I got were for a GTR but I thought I could get away with em on mine.
I realy gota get something thats staggered, like a 9 on rear an 8 on front....
Yea you could to make them look good but how are you gonna rotate them when the time comes???
Not gonna bother with rotating
Im prob gona end up running 275 on the rear and 245 on the front, itl just fit better that way.
where are you slack pricks? there's a boat here without a pilot... DBR33
Tragic, John, just tragic...
But I do love your art work!!! Mine is all undercover...
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
    • This. The R34 handbrake icon DOES come up when the brake fluid level is low. You might be sitting right on that threshhold. I have been down this diagnosis path and this was the solution (and it was pretty much as full as your picture is to begin with).
    • Unfortunately the cavaet to that is that while any scan tool should be able to read the code, the workshop will need a consult plug to OBD socket adapter. You don't have a location on your profile, where are you based?
    • @Haggerty this is your red flag. In MAP based ECU's the Manifold pressure X RPM calculation is how the engine knows it is actually...running/going through ANY load. You are confusing the term 'base map' with your base VE/Fuel table. When most people say 'base map' they mean the stock entire tune shipped with the ECU, hopefully aimed at a specific car/setup to use as a base for beginning to tune your specific car. Haltech has a lot of documentation (or at least they used to, I expect it to be better now). Read it voraciously.
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
