just got home 15mins ago, time is currently 2:46am
longest and worst f**king day ever..
on a higher note:
SR cranked over and sounded very very mean.. brought a huge smile to tristian and my face..
still needs a little more adjustment and engine diagnostics scan before i give it the ok to roll out
on a higher note:
still at work me
:D:):)
on a higher note:
:D oath buddy
"Bassed on" but not THE v44
Mark from godzilla who installed it told me.
Yeah V44 with 2 extra injector outputs, and a few more inputs. None of the extra features or anything the V88 offers. Bit of a dodgy sales pitch telling you its a mix of the V44 and V88
No biggy man the ecu works good for what I want it for and it was a good price
Haha does that come with a :D stick?
@Danski, hell yeah man, it's a great ECU. Currently on the top of my list for when I finally get around to an ECU for mine. I just hate dodgy sales c*nts giving misleading information
Haha does that come with a :) stick?
Wooo go vi-pec ;)
Yeah I know wat ya mean about dodgy sales pithces
    • It's almost certainly a reluctor generating an "AC" waveform. No, ECUs don't generally read those - they're usually set up for PWM square wave 0-5v stuff.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
