lol needs to be reversed so he's the one doing the cupping. No photoshop in work :P I would dload it but they would probably crack the shits.
i like tacos.
same. having them tonight, home made tho. Should go taco tuesday in the valley one night. 2 dollar taco ftw. Anyways...
http://www.keepbusy.net/play.php?id=zombie-kid-likes-turtles
Link for taco
http://www.thealibiroom.com/tacotuesday.html
OMG look what I found on tristans facebook :)
BAHAHAHAHA thats f**king hilarious
...colin only got away wiht that coz he told me he was his sister :(
The real worry for me dan, is where did you get the original pic from? your secret stash of gay photos aye? ;)
Link for taco
Tis a good idea.
:( Martin.
...colin only got away wiht that coz he told me he was his sister :)
*Busted :(
going to drop my missus at the airport in a few hours :(
i might go for a spirited drive afterwards to make myself feel better
any good places near the airport or such?
Edited by Redsuns88
    • With the system, once you drive it for a bit, and before you turn the car off, does the car fix its date and time? When you say the date is wrong, what date does the vehicle think it is, and does it always show the same date? My thoughts from a process driven view is; The system may be defaulting to a standard start date/time. The main reason you'd typically see this occuring, is the system is losing its constant/backup power supply.   If its always defaulting to the same date/time at start up, and especially if it fixes itself while driving, I'd say either the non volatile memory has an issue, or the power supply to the volatile memory that stores this information.   The other thing I'd check is if there is anywhere in the system you can adjust the date and time from. If the date/time is still moving forward since it wished you happy new year, then it is 100% possible the system has just had a bit of data corruption occur, and you likely need to find a way to reset the date/time in the vehicle.
    • Scissor Jacks are an accident waiting to happen, the only time they should be used are in an roadside flat, even then a tyre and rim should be placed underneath
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
