No Taz,
They are just a shit clutch and I will beat my little drum until I get a court order telling me to stop. But as my product failed, they have no legal grounds to shut me up.
Its not even the point, the fact they sold me a shit product that did this is a joke, the fact it was sold via HQ makes it even worse. THIS IS the clutch they told me I needed.
Then to not want to know about it after it happened.. Guess what I'll cost then more then a f**king vaule on the clutch by posting what I do
that sucks mate as you showed me before,
as martin said before everyone is entitled to their own thoughts.
i never had a problem with exedy clutches at all even when i had a HD clutch in my R32 or when sold customers exedy clutches and i still stand by exedy clutches..
It sucks that it happend due to lack of product knowledge
josh was this in your 450hp 32? cuz a HD aint really for that application... noob sales person.
hope my 5puk holds in better than that :D
For every person who has had a failed product there will always be 10 more who hasn't. It's is more the guys at HQ shouldnt be selling "shit" that will break.
If I make every mod known about a car and you sell me shit, I will kick, scream and cry until I get bored.
understandable.
- tristans hd stood up alright however would slip if you gave it a heap (clutch kick wise)
as you say there will be some who have never had a problem. but when you get a bad product that sucks.
Edited by 32_Dave
Yeh it was, I was getting my OS twin plate re built (note I'd only ever rebuild one with genuine OS plates next time but thats another story). I told HQ what my car was, what the sitution was (this is where anyone else would say, right he is a big spender lets sell him the best not worst).
They knew everything f**king known mod, they knew the boost was capped at 10psi MAX, told me black and blue this little unit would be perfect.
i am a banana (bor-na-nAAAAA!!!)
f**k haven't you guys seen this...
:D
click the banana
Edited by 32_Dave
WOW thats a real mess, I hop mine doesnt end up like that :D
if yours was goin to blow it would have already man. that clutch was way too weak for the power. they only baby clutches. exedy clutches can be awesome but with some modification.
Mine was parked on the street near work all day, and apart the windscreen you almost wouldn't know its dirty! <3 the yellow :)
mine was white.....
mine was black, white, orange, dust orange and rust orange :):(
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
