Yea touche. I dunno how keen I am on it. He wants to leave from Jimboomba at like 5-6am. I wanted to go Casino on Saturday night n make some money ;)
damn thats fking early, might have to involve spending the night at your house
which of course comes with additional benefits if your sister will be home *pitches tent*
Edited by Smity42
*fap fap fap*
tig old bitties
*fap fap FAP FAP FAP FAP*
Colin: maybe you should bring your sister along tonight
*FAP FAP FAP FAP FAP FAP FAP FAP FAP FAP FAP FAP FAP FAP FAP*
sleep saturday day time, get up late, go to casino, then go driving :)
Gotta work Saturday. Might involve f**k loads of Mother. Casino 6pm - 4am. Back to my place for 5am. Go for drive after another 6 mothers get home and have a heart attack. Somehow I think thats a bad idea though. Mountain run while tired just seems dangerous lol.
:blush:
tig old bitties
:P
:D
*fap fap fap*
:domokun:
I hate you guys...
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
