yea bring the tank any time/
edit: thought u was talking about your 'woo for a split second
ROFLCAKES! no way! you guys don't need that f*cker down there blowin' smoke all up in your shit! :merli:
I'll see if I can find some pants... put them on, and then bring it down. Coffee too?
Just finished work.
Started at 8am yesterday.
How was the meet. Bummed I missed out on this one, as it looked like it was going to be a decent turnout
ps. out at the chalk on Sunday arvo around 4pm if anybody is keen.
Just finished work.
You didn't miss anything this week buddy, was a pretty poor turnout intelligence wise. Was good once it was back to the regular crew + a few other smart kids though :merli:
Now, go get some sleeeeeeep!!!
lol
will have to make the next one to catch up on the goss. or you farkers can drag your asses out to the chalk on sunday and have a few cheap beers.
there is stand up comedy on as well..
NO SWAPS NOW - HAVE ANOTHER CAR
MONEY SALE ONLY
Have just done:
- New timming belt
- New timming belt bearings
- New/Replacement CAS
- Replacement radiator
- Replacement fuel pump (still have old one here in box)
- re-installed standard clutch fan and shroud
- New plugs, oil, etc
All work done by ERD except the plugs, oil change and replacement pump. This car now has ZERO maintenance for it's new owner, car also now has full 6 months rego.
No swaps.
$6850ono
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
