yea bring the tank any time/
edit: thought u was talking about your 'woo for a split second
ROFLCAKES! no way! you guys don't need that f*cker down there blowin' smoke all up in your shit! :merli:
I'll see if I can find some pants... put them on, and then bring it down. Coffee too?
Just finished work.
Started at 8am yesterday.
How was the meet. Bummed I missed out on this one, as it looked like it was going to be a decent turnout
ps. out at the chalk on Sunday arvo around 4pm if anybody is keen.
Just finished work.
You didn't miss anything this week buddy, was a pretty poor turnout intelligence wise. Was good once it was back to the regular crew + a few other smart kids though :merli:
Now, go get some sleeeeeeep!!!
lol
will have to make the next one to catch up on the goss. or you farkers can drag your asses out to the chalk on sunday and have a few cheap beers.
there is stand up comedy on as well..
NO SWAPS NOW - HAVE ANOTHER CAR
MONEY SALE ONLY
Have just done:
- New timming belt
- New timming belt bearings
- New/Replacement CAS
- Replacement radiator
- Replacement fuel pump (still have old one here in box)
- re-installed standard clutch fan and shroud
- New plugs, oil, etc
All work done by ERD except the plugs, oil change and replacement pump. This car now has ZERO maintenance for it's new owner, car also now has full 6 months rego.
No swaps.
$6850ono
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
