Super Advans ftw. Although most need less offset and more wide.
John its Clagiraba road :P
Tristan. Rap is gay.
Croissants and Jam are good.
End.
omg queeers..
have a look i was lokoing at enkeis site
http://www.enkei.co.jp/jp/products/wheels/index.html
anything specific we were meant to be looking at? that's the entire collection lol
i would have stolen your wheels if they were 4 stud :P
god you're soft... just take the axles as well!!
toaster at work has aids. So no crumpets for me. That said in the part of the UK I'm from its more like tea and crack.
EDIT - Sentence didnt make sense. Probably still doesn't. Tristan drives a tractor.
Same, my toaster is circa 1940's :P
Them be the good ones. Last forever. Its modern POS ones that a crap and built to sell for $5
well hopefully I'll be up and running by the time we're doing it!!
ORLY?
Afternoon all!
Hope everyone's had a great Tuesday so far lol
all that lurking and thats all you could come up with..
Can I call you my bitch?
dont know if i like that one
dr tre sounds better :P
Same, my toaster is circa 1940's :happy:
I need a sandwich toaster so I can make ham cheese tomato toasted sandwiches :)
I dont think my tires have 2hrs left in them :P
She'll be right mate.
I'm in. When?
Discuss on Thursday
Dam straight
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
