I own a GHD..
No really, I do.
I bought my sister one of them for christmas one year. When I bought it the woman in the hairdressers was lookin at me weird. FFFFUUU Bitch! f**kin exxy shit aswell.
hey hey hey!
mmmm, i see how you're playing the game here
180 is down for some skidpan :P
I'm down for skidpan
Question Guys!
I need some help with tyres here. Wife's new beetle gonna be here next month and she's getting 17s for the car, so obviously she'll need tyres. What would you recommend?
Model Noise Wear Price Grip TOTAL
RE001 2 2 1 2 7
KU31 3 3 3 2 11
KU36 2 1 2 3 8
595 SS 3 3 3 2 11
595 Evo 2 2 2 3 9
Size that I'm getting is 215/45/17 and judging from the price I've got here, KU31 (option1, cheapest) and SS (ERD, cheapest) are the best compromise between noise/price/wear. What are your thoughts?
Get the SS. I've got no complaints on mine. Brilliant everyday tyre.
Question Guys!
RE001 2 2 1 2 7
KU31 3 3 3 2 11
KU36 2 1 2 3 8
595 SS 3 3 3 2 11
595 Evo 2 2 2 3 9
Brandon... I'd recommend Linglongs.
LINGLONGS FTW!
is it the turbo beetle or na?
I'd go for 595s or 535s respecitvely... if I wasn't buying Linglongs that is!!
Ok, I'm just gonna ignore the rest. :P
Colin: yea thats what I thought too but dont know if noise will be an issue. KU31 is cheaper so its a tough 1.
chinese/taiwanese
basically the same shit..
SAME SAME BUT DIFFERENT LAH!
FAIL
Taiwanese uses "MEH" for that sentence, Chinese uses "BEH" and Singapore/Malaysia uses "LAH"... Talk about multi-cultural...
I gave you a normal answer as well. the 59s and the 53s are both quiet. I've been in Colin's car when he's been giving it some and the only time we noticed the tyres was when they squealed a little on a corner or two.
The 53s I had on the Capri for ages and are also great.
Come for a spin in mine on thursday and you can see what the noise is like. It doesn't bother me there are a lot of things that are noisier in my car than the tyres.
Thats the exact reason why I'm asking. I cbf about the noise on mine as the exhaust will be louder but on her beetle its different. The CR KAI I sold to my friend had some ling longs on them (cheapass) and I didnt know they're noisy until he put them on his cefiro. Its very annoying to hear thats for sure, sounds like bee buzzing.
John: its the actual tyre being noisy and not from lost of traction etc. Generally better gripping tyres are noiser than lesser gripping ones. And thats why I'm checking whats the best compromise between them.
Nope but its actually around 75kW if you wanna know. The last beetle before the new facelift thats coming soon.
To be fair though, I love all things Volkswagen and have owned two beetles, and did my driving test in a new beetle. They are great cars and go pretty hard. The federals will increase the handling on it, but I would also look at suspension, it's pretty soft, and can affect cornering a bit. I'd just go with 535s though, for an NA Beetle. I would have used 595s on the turbo version.
Obviously your call, but my input as a Volkswagen and federal user :P
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
