You are easily pleased then. f**ked if I'd pay over $1000 for a second hand POS clutch that may or may not explode at any time.
Can build and sell retail the EXACT same thing for half the price using all new parts.
Astro:
And 3 puk? WTF were you thinking? I hope you don't care about ya neck
explain sir?
hmmmm... looks like I've missed nothing so far...
*scampers back into the shadows**
hahah its a bit like that for me today
Careful tristan The Jewish are after you!
huh jews?
i cant think of a jew without thinking about borat hahah
politically incorrect, but hilarious
explain sir?
Have you ever driven on a 3 puk button clutch before?
What is the car being used for? And how much power does it make/will it be making?
Racist much?
hand over the jew gold, kyle
Side note : Did i tell you's that if i can get enough donations I will be growing a hitler still moustache for movember... but I might call it a chaplin... not sure the jury is out on that one.
nope i havnt, car should be making around 220kw-ish + if everything goes sweet, used as a dori machine
Then a 3puk clutch is a poor choice. Whoever advised you on this needs educating.
You may end up liking it but it is EXTREMELY harsh on driveline stuff. Say goodbye do diff, gearbox and universal joints. You'll jolt your neck every time you take off but it'll kick nicely for drifting. But then again, so will a 5 or 6 puk button clutch but it won't be as hard on everything.
3 puk should be good to hold 350+rwkw, 6puk at 300rwkw and 5puk at 350rwkw.
So basically the wrong clutch for the job
Plus when the clutch wears out you will need a new flywheel. Because from all the clutch riding you are going to be doing while you drive it on the street, it will machine a large deep groove in the flywheel.
*plays dramatic music while waiting for Elite Racing's reply"
I've got 5 minutes spare if you want some lessons. Hmm, on second thought, might need a decade.
I was happy.. Knowing what happened with Noel and knowing what really goes on after reading about parts, not so happy. I was a lucky one. Back in 02/03 when the clutch was bought there wasnt really a huge aray to pick from.. Started with an OS twin plate, shagged it. JB worked, heh.
Not easily pleased, you know this.
you raise a very good point, i didnt take into account my drive line ;)
oh dear :(
I just assumed from the car you drive.
Oops did I say that out loud
Im pleased that car runs. Im a slave to offset. It's in keeping with mud crabs and so forth I guess.
That car now is in better mech nic then half the shit boxes on car sales :(
oh dear :(
And just to clear up what I believe Taz is getting at:
I don't give two flying rats arses who sells you a clutch, installs your clutch or whatever....I am here for advice only, not to pick up work.
I fit around 30 or so clutches a year to Skylines and silvias and have done for the last 6 years. Just telling you how it is.
All my cars have had button clutches fitted so I know what it's like to drive them. I have sold and fitted many to others and can tell you it's hard enough satisfying people with a 6puk clutch (which is AT LEAST twice as easy to drive than a 3puk) when they have never driven on them before. There is only two reasons for needing to go button in the first place.
1: The car makes more than 300rwkw
2: Drifting
Why can I never get a bite out of you? You wanna have sex with me don't you?
    • Today, I'm a Breville BES920 tech, new triac board and new 3x way solenoid. Had overheating issues, home RCD tripping when it got warm, and the boiler stayed on when the machine was shut off. Also, usually 3x way solenoid chatter, this is the 3rd time I'm replacing it. Mind you, this machine is 9 year old and send it every day doing at minimum 3x double shots. When the in laws come over to took after my daughter, it will easily see 6x double shots in a single day. Tried to be somewhat compliant, crimped and then used a screw connector over the top. Would have preferred to use heat shrinks.   After all that, turns out all the overheating has damaged the o-rings to the steam tap as well. Ordered new ones, coming soon.
    • Still got it- First time checking sau in a while ahhaha
    • I don't know about that. I can hoon my R32 around - hard launches, high lateral Gs - with <<1/4 tank without any such shenanigans. This with the previous 040 and the current GSS342. I would suspect a fuel line problem. One of the hoses associated with the top of the tank perhaps.
    • This is amazing. Love that you’re giving the boys an intro to cars and off the screens. They probably have an insta for the car and build posts on TikTok for their mates.
    • It is.  Your car works fine with the tank full. If you drive like a Nana it works fine.  You give it a boot full with half a fuel tank, you get surge.  It 100% is a fuel surge issue. Maybe have a look at installing a Hydramat if you don't want to install a surge tank.  https://www.holley.com/products/fuel_systems/hydramat/
