I mang in the office mang. Bashing head against keyboard styles :)
@Colin: I may be able to drive the GT-R to willowbank for the drags for ya :D
I also mang it up in the office.
A mang is... well webster's dictionary defines it as...
umm...
It's a cool word though mang
Gramlight 57d got those fluoro colours and they're pretty affordable.
gramlights affordable? ;)
With the R33 I'd be going for a 5 or 6 spoke rim. LMGT4, TE37, GTCs or go for mesh rims like BBS LMs or Work VS-XX
In other news the unit now has power :) Only phone n internets to sort out now. Win.
Yes. Not all Gramlight but the specific design I'm suggesting. The 57d were quoted by Streeter
Gram Light 57D 18" x 9.5J +12 22,910yen eachRough costs on that would be something like this...
Cost of item ¥91,640
Ship item to me ¥0
Bank fee to pay seller ¥630
My commission ¥7,000
Removing 4 tyres ¥0
Shipping to Aus via Sea assuming 13 kg ¥31,200
* (I could be off with the weight but what ever it costs to send Ill
pass on to you)
ROUGH TOTAL in Yen: ¥130,470
ROUGH TOTAL: $1,875
Comparing to
TE37 in 18" x 10.5J +22 52390yen each
*this quote is based on sea post, they are over max size so there is
a change they might have to be sent by EMS.
Cost of item ¥209,560
Ship item to me ¥0
My commission ¥14,000
Removing 4 tyres ¥0
Shipping to Aus via Sea assuming 12 kg x4 ¥29,800
pass on to you)
ROUGH TOTAL in Yen: ¥253,990
ROUGH TOTAL: $3,649
*depending on exchange rate. current rate is 72.9
These would be a lot cheaper with the current exchange rate sitting around 85?
I got told today theres a high chance of me heading up to site either in Jan or Feb.... WOOOOOooooo COILOVER HERE I COME!
Dudeman why dont u just get a job on a mine site and then you can earn sweet moneys ?
Nah dw Martin I think it's probably better my car doesn't go the drags. The noises the gearbox is making atm are pretty disgusting. Another thing on the list for while its off the road.
Comparing to
Yeah but those gramlights are pretty gay. If you're going to have them you have to have the 57 Pros.
What site?
All the arse rape puts me off working in the mines.
I wanna know the design part of things rather than operational for starters. And I'll need the commission experience if I wanna go down the path I'm planning.
    • Before all the EFR fan boys come in, have a look at: https://www.garrettmotion.com/racing-and-performance/performance-catalog/turbo/g-series-ii-g30-825-58mm/ It also comes in a T4 1.06 divided housing. I would dare say if you want response & also decent power, this thing would chop.   AND apologies, just re-read your post, you've already bought the turbo... whatever you do, make sure you stick with divided housing and proper twin scroll manifold.
    • People have got to stop doing that. ShatGPT is not a search engine. It is a hallucination factory.   I also would recommend the 1.05. The .83 will "work" for you , in that it will be more responsive, but I think you'll find that it won't be anywhere near as good running it out to 8000rpm as the big housing will be.
    • Decided for the first time ever I would tow my car TO the track day on the same working theory as bringing tools and spares "if I have it I wont need it, but if I leave it behind i will 100% need it" all setup and ready to go out and try these A050 for the first time First session showed I needed to stiffen up the dampers a touch but still managed a few 1:21's without much effort. things were looking good. Came in a dropped the tyres down  to 26/28 as they had gotten to 35/33C from 22C cold The first lap of session two I managed to drop into 1:20's. Then in the second lap into the second session. Coming into T3 and I suddenly lost brake pedal followed by some huge rear end vibrations and scraping sounds. Got it back into the pits after session ended and found this. in the attached video, all of the wobble is in the hub its self, wheel is mint, and bearing feels tight. lKXLqpd - Imgur.mp4   Deciding it was a bent spindle I tried to find bearing/hub assembly locally but was unsuccessful so it was loaded back onto the trailer i luckily brought it on to drag it back home
    • 1.05 you’ve gotta let it breath
    • You have to continuously fill it to avoid dry running. Personally the transmissions I've serviced have never been bad enough to justify doing this because it is definitely a pretty complicated and somewhat risky procedure compared to simply draining the pan, measuring what came out, then refilling with the exact same amount.
