finally finished guards and repaired dint in rear quarter... now its all masked and ready to sandblast / paint. :P
fap fap fap fap fap fap fap :cool:
Woooo sick mangz bet your stoked
you fuggen know it.
Have you decided on a colour dave?
black my friend. found a black from a old falcon its jet jet jet black, soo sexy. ive already sprayed it on the interior, looks good
Edited by 32_Dave
finally finished guards and repaired dint in rear quarter... now its all masked and ready to sandblast / paint. ;)
f**kin noice. :D
sex cadet
:D Was gunna message you to see if you were out yachting but my phone died and now it won't charge :( f**king stupid iphone.
I'd hit it
:wub:
needs more xmas hat
Put an xmas hat on it for me n ill use it for an avatar like all the cool people.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
    • From memory it wasn't too hard to simply see which wire ran where when you plug that in. Unfortunately also from memory the OEM sender does not use the same configuration 99.9% of gauges run. So in other words if you connect the signal wire that was running to the OEM gauge to your DEFI gauge you might find your oil reads at 200C or some other incorrect value. I remember having the same line of thought and then running new wires/senders to match the gauges I have. The pinout is available in the R34 workshop manual.
    • Does anyone on here know which wire on the GTT triple gauge pod harness is for the oil temp gauge? my sensor works fine but I upgraded the gauges to DEFI advance. And if I can simply piggyback off the oem oil temp wire to the Defi oil temp sensor wire that would make life so much easier.
    • Even face her a wash now that’s it worth more than my house
    • This was what I was invisioning, or Pete cutting a beer can up and hose clamping it around the catch can! Ha ha ha
