nice one bro!
all sorted and delicious
f**k yeah!
awesome news john!
She doesn't like that dirty ass pod filter on there though lol (which was also a mission to try and fit into my engine bay btw). So all I need to do now is get myself a new AFM :D
Yea I dont mind drive a lil but hows the spit like on a Saturday thats my only concern...
Dead as a doornail, just people fishing and shit, besides what the f**k you wannago down there for? I have 65mm ride height, I ain't beaching my shit on the crazy high speed humps down there!
I just pm'd you a link to the guy with the hks pod and afm. Offer him 60ish maybe??? His english aint too good tho...lol. Good guy though
fits easy cause there is nothing in that engine bay
I vote we make Johns engine bay just as empty
so i finally got around to putting my avatar up, only 3 years after joining.....
Its missing a santa hat
Hahaha. The original plan with Dan and Colin was to go to the spit and chill. But 65mm... DEFECT! Mine's a 4WD so no worries here :D
Is there anyone thats keen for gold coast today or not?!?!??!?! Sky looks a bit shit here though.
http://www.bom.gov.au/products/IDR673.loop.shtml
Yup. Gold Coast looks f**ked later today. I think Peter's not gonna happen.
65mm ride height!! Jesus I envy/feel sorry for you.... even at 110mm I scrape driveways and have nightmares in shopping centre carparks.
Legal height is 100mm isn't it ?
Yep sure is.
Can anyone clarify info about R32/R33 bovs.... are the mounting flange the same size/shape? Would one with 32 adapter bolt directly onto my 33 crossover pipe?
Edited by mosquitocoils
The GTR doesn't go anywhere near shopping centre carparks, nor speedbumps :)
I'd go lower but I can't get out of my driveway! I've had it at 55mm before but its too stupid..
Yep sure is.
same size/shape
same size/shape
Excellent, thanks a lot.
Can anyone tell me if there's any adjustment to be made on this version of HKS SSQ? Doesn't appear to be any visible screws or anything, but it comes with a couple of different springs... and I've been told you can go get some different size/strength springs from a hardware shop to get your own 'custom' tension.... can anyone agree/disagree?
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
