Hey also John, that sounds like a pretty sweet show..... seeing as the girlfriend and I broke up on the weekend I think I'm gonna need a new show to get in to for the time being hahaha. Might bring some blank DVD's to next ice cream meet if you'd care to burn the first season for me?
Mad props to TPG who just waived the 30 day cancellation notice for me because I asked nicely.
Not like last time, when they were absolute f*ckbags and it ended up costing me several hundred dollars just because the name the phone line was in had changed.
Must be improving their customer focus.
...Still don't have the new interwebs connected though :), but I am blaming Telstra for that. Apparently it does actually take them 10-20 days to connect it, and I am only 7 or 8 in so far
Yeah telstra was what held us up last time too
Telstra and TPG both suck at customer service tbh. TPG only have customers because their plans are better. But I'm all connected now. Just gotta figure out why my dload speed is so terrible.
Thanks for the input on the coolers everyone. And no Colin, I don't want to cut my front bar. I'd rather get called a pussy by a dirty ranga scouse. You'd be amazed how well that just brushes off :)
I'll look into what everyone has said and measure up the space behind the front bar.
Tas you cheap two dorra whore. I just finished helping mum with all these books, so I'm on my way down. If you crazy asians bastards want coffee, text me your order.
try..
/porn off
Tried failed.
Scouser is the correct term. Take off your skirt and chop that front bar all the cool kids do it.
just got back from ERD, Dan is the best :)
went to TintACar in milton to get my windows tinted, turns out business is so slow these days they close up around 230 or 3 LOL, well they could have made 350 today, guess theyl have to make it tomorrow now.
and car feels awesome, way smoother power delivery now.
your dad even wants to drive your car? my old man drove mine when it had the stock suspension in and complained that it was too low and too hard.
Hahahahahaha yeah, when I first bought he was all excited, thinking back to his sports car celica days :) and was superkeen to take it for a spin around the block, with my step mum in the passenger seat, and me in the back......
It was dumped on coilovers, and yep, he sure did complain. Nearly stalled a few times with the heavy duty clutch that was in it...
But boy did he love the power ;)
Edited by mosquitocoils
Gayness....back from holidays and back to real life which is fail ;)
You may have a problem with this at first like I did. Make sure you have a filter on every line in your house and then check you line noise. If everythings in order, call them malaysian american farks and go off at them
Whenever I take off my skirt for the boys they don't call me in the morning :(
They just like to use and abuse you man :) Wanna make out though?
Woot!!...spent all day weilding and my bottle finally runs out.. now went to replace it and i got this awesome pungent smell in my car..
lol
FFS tas stop saying weilding. You wield a sword. Metal you WELD
LOL
+1
Whenever I take off my skirt for the boys they don't call me in the morning ;)
I would <3
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
    • Could be correct. Meter might be that far out. Compare against a known 5 ohm 1% resistor.
    • @Murray_Calavera  If I were an expert I wouldn't be in here looking for assistance.  I am extremely computer literate, have above average understanding on how things should be working and how they should tie together.  If I need to go to a professional tuner so be it, but I'd much rather learn and do things myself even if it means looking for some guidance along the way and blowing up a few engines. @GTSBoy  I was hoping it would be as simple as a large vacuum leak somewhere but I'm unable to find anything, all lines seem to be well capped or going where they need to be, and when removed there is vacuum felt on the tube.  It would be odd for the Haltech built in MAP to be faulty, the GTT tune I imported had it enabled from the start, I incorrectly assumed it was reading a signal from the stock MAP, but that doesn't exist.  After running a vacuum hose to the ECU the signal doesn't change more than 0.2 in either direction.   I'll probably upload a video of my settings tomorrow, as it stands I'm able to daily drive, but getting stuttering when giving it gas from idle, so pulling away from lights is a slow process of revving it up and feathering the clutch until its moving, then it will accelerate fine.  It sounds like I need to get to the bottom of the manifold pressure issue, but the ignition timing section is most intimidating to me and will probably let a pro do that part.  Tomorrow I'll try a different vacuum line to T off of, with any luck I selected one that was already bypassed during the DBW swap.  (edit: I went out and did it right now, the line I had chosen did appear to have no vacuum on it, it used to go to the front of the intake, I've now completely blocked that one off at the bracket that holds several vacuum lines by the firewall.  I T'd into the vacuum line that goes from that bracket to the vacuum pump at the front of the car, but no change in the MAP readings).  Using the new vacuum line that has obvious vacuum on the hose, im still only getting readings between -6.0 and -5.2.  I'm wondering why the ECU was detecting -5.3 when nothing was connected to the MAP nipple and ECU MAP selected as the source. @feartherb26  I do have +T in the works but wanted to wait until Spring to start with that swap since this is my good winter AWD vehicle.  When removing the butterfly, did it leave a bunch of holes in the manifold that you needed to plug?  I thought about removing it but assumed it would be a mess.   I notice no difference when capping the vacuum line to it or letting it do its thing.  This whole thing has convinced me to just get a forward facing manifold when the time comes though.
    • Update: tested my spark plugs that are supposed to be 5ohms with a 10% deviation and one gave me a 0 ohms reading and the rest were 3.9ohm<, so one bad and the others on their way out.
