Hey also John, that sounds like a pretty sweet show..... seeing as the girlfriend and I broke up on the weekend I think I'm gonna need a new show to get in to for the time being hahaha. Might bring some blank DVD's to next ice cream meet if you'd care to burn the first season for me?
Mad props to TPG who just waived the 30 day cancellation notice for me because I asked nicely.
Not like last time, when they were absolute f*ckbags and it ended up costing me several hundred dollars just because the name the phone line was in had changed.
Must be improving their customer focus.
...Still don't have the new interwebs connected though :), but I am blaming Telstra for that. Apparently it does actually take them 10-20 days to connect it, and I am only 7 or 8 in so far
Yeah telstra was what held us up last time too
Telstra and TPG both suck at customer service tbh. TPG only have customers because their plans are better. But I'm all connected now. Just gotta figure out why my dload speed is so terrible.
Thanks for the input on the coolers everyone. And no Colin, I don't want to cut my front bar. I'd rather get called a pussy by a dirty ranga scouse. You'd be amazed how well that just brushes off :)
I'll look into what everyone has said and measure up the space behind the front bar.
Tas you cheap two dorra whore. I just finished helping mum with all these books, so I'm on my way down. If you crazy asians bastards want coffee, text me your order.
try..
/porn off
Tried failed.
Scouser is the correct term. Take off your skirt and chop that front bar all the cool kids do it.
just got back from ERD, Dan is the best :)
went to TintACar in milton to get my windows tinted, turns out business is so slow these days they close up around 230 or 3 LOL, well they could have made 350 today, guess theyl have to make it tomorrow now.
and car feels awesome, way smoother power delivery now.
your dad even wants to drive your car? my old man drove mine when it had the stock suspension in and complained that it was too low and too hard.
Hahahahahaha yeah, when I first bought he was all excited, thinking back to his sports car celica days :) and was superkeen to take it for a spin around the block, with my step mum in the passenger seat, and me in the back......
It was dumped on coilovers, and yep, he sure did complain. Nearly stalled a few times with the heavy duty clutch that was in it...
But boy did he love the power ;)
Edited by mosquitocoils
Gayness....back from holidays and back to real life which is fail ;)
You may have a problem with this at first like I did. Make sure you have a filter on every line in your house and then check you line noise. If everythings in order, call them malaysian american farks and go off at them
Whenever I take off my skirt for the boys they don't call me in the morning :(
They just like to use and abuse you man :) Wanna make out though?
Woot!!...spent all day weilding and my bottle finally runs out.. now went to replace it and i got this awesome pungent smell in my car..
lol
FFS tas stop saying weilding. You wield a sword. Metal you WELD
LOL
+1
Whenever I take off my skirt for the boys they don't call me in the morning ;)
I would <3
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
