your so kinda to me moistsack...
i love you long time!
dont be upset i punched her in the mouth when i had my way with her..
i was just excited thats all :$
Edited by Redsuns88
Gayness....back from holidays and back to real life which is fail ;)
You may have a problem with this at first like I did. Make sure you have a filter on every line in your house and then check you line noise. If everythings in order, call them malaysian american farks and go off at them
They just like to use and abuse you man :) Wanna make out though?
have filter on the line that the adsl is connected to. I dont have anything else connected to the phone line so I figured that would be sweet. I'm probably only 250m at most away from the exchange too. I updated all my network card drivers n shit like that still only get 260kb/s dload. I'll probably call them tomorrow.
Call them hoebags and go off. They won't take you seriously unless you make a complaint about the service. They'll do a line test and then get you to mess with your settings. What modem you using? Dlink by any chance??
I have no idea who you're referring to, but that made me seriously LOL hahahahahahah
Did u get 2 cartons of that raddler?
if so.. f**king LOL shittest beer!
its like that lime beer, makes u dry reach!
No, one carton of XXXX and one of carlton :)
You shouldn't filter the line that the adsl is on...
If you have a 'splitter' that has an input and 2 outputs (one that says 'phone' and one that says 'adsl' or 'modem') then that's ok, just make sure you use the adsl/modem one. But if its just a plain old filter (one input one output) f**k it off, it'll be filtering out most of your adsl bandwidth
damn, i wish i could get out there and do that. Having a full time job is bullsh*t
take a day off :)
it was a sweeet day, less than a month til the next one :)
I have about 3 weeks holidays saved up at work, all of which i will be needing,
I could pull a sick day though....
i say it sounds like a plan :)
Looking good John, lol
haha thanks mate, I like number 3 the best. Looks like epic T wing action! - I just need the proper feet for it now :) so if anyone knows of anyone selling GTT spoiler feet I need the ones with the L shaped base. :)
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
    • From memory it wasn't too hard to simply see which wire ran where when you plug that in. Unfortunately also from memory the OEM sender does not use the same configuration 99.9% of gauges run. So in other words if you connect the signal wire that was running to the OEM gauge to your DEFI gauge you might find your oil reads at 200C or some other incorrect value. I remember having the same line of thought and then running new wires/senders to match the gauges I have. The pinout is available in the R34 workshop manual.
    • Does anyone on here know which wire on the GTT triple gauge pod harness is for the oil temp gauge? my sensor works fine but I upgraded the gauges to DEFI advance. And if I can simply piggyback off the oem oil temp wire to the Defi oil temp sensor wire that would make life so much easier.
    • Even face her a wash now that’s it worth more than my house
    • This was what I was invisioning, or Pete cutting a beer can up and hose clamping it around the catch can! Ha ha ha
