your so kinda to me moistsack...
i love you long time!
dont be upset i punched her in the mouth when i had my way with her..
i was just excited thats all :$
Edited by Redsuns88
Gayness....back from holidays and back to real life which is fail ;)
You may have a problem with this at first like I did. Make sure you have a filter on every line in your house and then check you line noise. If everythings in order, call them malaysian american farks and go off at them
They just like to use and abuse you man :) Wanna make out though?
have filter on the line that the adsl is connected to. I dont have anything else connected to the phone line so I figured that would be sweet. I'm probably only 250m at most away from the exchange too. I updated all my network card drivers n shit like that still only get 260kb/s dload. I'll probably call them tomorrow.
Call them hoebags and go off. They won't take you seriously unless you make a complaint about the service. They'll do a line test and then get you to mess with your settings. What modem you using? Dlink by any chance??
I have no idea who you're referring to, but that made me seriously LOL hahahahahahah
Did u get 2 cartons of that raddler?
if so.. f**king LOL shittest beer!
its like that lime beer, makes u dry reach!
No, one carton of XXXX and one of carlton :)
You shouldn't filter the line that the adsl is on...
If you have a 'splitter' that has an input and 2 outputs (one that says 'phone' and one that says 'adsl' or 'modem') then that's ok, just make sure you use the adsl/modem one. But if its just a plain old filter (one input one output) f**k it off, it'll be filtering out most of your adsl bandwidth
damn, i wish i could get out there and do that. Having a full time job is bullsh*t
take a day off :)
it was a sweeet day, less than a month til the next one :)
I have about 3 weeks holidays saved up at work, all of which i will be needing,
I could pull a sick day though....
i say it sounds like a plan :)
Looking good John, lol
haha thanks mate, I like number 3 the best. Looks like epic T wing action! - I just need the proper feet for it now :) so if anyone knows of anyone selling GTT spoiler feet I need the ones with the L shaped base. :)
    • @Murray_Calavera  If I were an expert I wouldn't be in here looking for assistance.  I am extremely computer literate, have above average understanding on how things should be working and how they should tie together.  If I need to go to a professional tuner so be it, but I'd much rather learn and do things myself even if it means looking for some guidance along the way and blowing up a few engines. @GTSBoy  I was hoping it would be as simple as a large vacuum leak somewhere but I'm unable to find anything, all lines seem to be well capped or going where they need to be, and when removed there is vacuum felt on the tube.  It would be odd for the Haltech built in MAP to be faulty, the GTT tune I imported had it enabled from the start, I incorrectly assumed it was reading a signal from the stock MAP, but that doesn't exist.  After running a vacuum hose to the ECU the signal doesn't change more than 0.2 in either direction.   I'll probably upload a video of my settings tomorrow, as it stands I'm able to daily drive, but getting stuttering when giving it gas from idle, so pulling away from lights is a slow process of revving it up and feathering the clutch until its moving, then it will accelerate fine.  It sounds like I need to get to the bottom of the manifold pressure issue, but the ignition timing section is most intimidating to me and will probably let a pro do that part.  Tomorrow I'll try a different vacuum line to T off of, with any luck I selected one that was already bypassed during the DBW swap. @feartherb26  I do have +T in the works but wanted to wait until Spring to start with that swap since this is my good winter AWD vehicle.  When removing the butterfly, did it leave a bunch of holes in the manifold that you needed to plug?  I thought about removing it but assumed it would be a mess.   I notice no difference when capping the vacuum line to it or letting it do its thing.  This whole thing has convinced me to just get a forward facing manifold when the time comes though.
    • Update: tested my spark plugs that are supposed to be 5ohms with a 10% deviation and one gave me a 0 ohms reading and the rest were 3.9ohm<, so one bad and the others on their way out.
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
