LMAO
This mangy mangness is getting outta control mangz
NEVER!!! You can never have too much mang.
I was watching that this morning too. They're cool.
+1
Just get home and watch it, my explaination won't do it any justice.
You'll have to splain it to me my wireless intertubes has the aids
poo to your wireless intertubes.
Basically of a guy singing his song called "pants on the ground" on american idol. very catchy tune.
sounds like im missing out
sounds like i should get some better tubes
*yawn..
Drinkin beers and palying left for dead 2 last night
its fun
machete is my weapon of choice
havent played it yet
is it really good?
* waits for the 6 hour response *
Yeah, I basically cream every time I see a good GTR in person...... 33/34.
32 GTRs just don't do it for me really.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
    • From memory it wasn't too hard to simply see which wire ran where when you plug that in. Unfortunately also from memory the OEM sender does not use the same configuration 99.9% of gauges run. So in other words if you connect the signal wire that was running to the OEM gauge to your DEFI gauge you might find your oil reads at 200C or some other incorrect value. I remember having the same line of thought and then running new wires/senders to match the gauges I have. The pinout is available in the R34 workshop manual.
    • Does anyone on here know which wire on the GTT triple gauge pod harness is for the oil temp gauge? my sensor works fine but I upgraded the gauges to DEFI advance. And if I can simply piggyback off the oem oil temp wire to the Defi oil temp sensor wire that would make life so much easier.
    • Even face her a wash now that’s it worth more than my house
    • This was what I was invisioning, or Pete cutting a beer can up and hose clamping it around the catch can! Ha ha ha
