Proved my point for me :sick:
So I'm sitting at home waiting for the Telstra people to come and install a line so that we can get TPG. Optus changed all their internet plans and they're absolute shit.
They said they'll be here between 10 and 2... but I'm tired, and slept like crap last night and really want a shower to help wake me up, but I can't, because I know as soon as I get in there they'll turn up and I won't hear them and they'll leave.
*sigh*
I hope they hurry up...
i bet they'll be tehre at like 1:45
hate shit like that - when they give you this window of like 4-6hours n you're like omg i have shit to doooooooo
Well... he's here... but not filling me with confidence... He calls the phone saying there's no one home. I open the door and there's no one there. Turns out he's in the unit complex next door...
:sick:
You do shift work ?
No, but I start early, and if I have done enough hours for the week (which I have) I can leave early on fridays :)
:sick:
LOL
It wasn't a black one by chance? With what seemed to be carbon fibre everything, and black (maybe nismo) 5/6 spoke wheels?
Yes. MIR34's the plate.
Anyone keen for lunch????
aaaannnd the Telstra guy just killed my Optus internet connection. Wicked.
If he is changing your phone line from optus to telstra, you should have expected that...
Alljap at Virginia for the indicator
Definitely lowball those mofos. Overpriced bastards...
3 hours to go. Kiwis installing 30 tonne props in the basement can't read a drawing. 750mm away from the end of the column so they put it 750mm away from the reo in the column = 150mm to close to the column = pissed off kiwis when I tell em they did it wrong.
Anyone else hear about Q1 sinking? Sounds like fun.
110 for a indicator!
they're like 40 on the forums man... i think i just saw one before
DOOOONT BUY IT YET!
ps nismo boy you around?
ugh gay icant find it
i found this which might be worth a go gts4 front cut
but as i said man around $40ish is what i've seen them for - so id bargain with the wreckers, (they're used to it), or wait and find one off the forums, or "i don't bargain because it's rude" and pay$110 :D
Probably overpriced, always are. Try All State Automotive it's in delta street, ask for Nick, tell him you know Ravi with the Maroon 33... he should be able to do better for you.
Ahhh man that thing is hell tough. Think he had some thermal coating done yesterday, not sure on the details though. Thermal Edge Coating is across the road from where I work... my boss and I heard a loud ass RB come tearing down the street..... then the high pitched squeal of an SSQV... *drool* so we ran out to see it pull in the shop.
I regret selling my SSQ now.
Anyway... yeah, that 34 GTR is off tits!
Edited by mosquitocoils
    • Update: tested my spark plugs that are supposed to be 5ohms with a 10% deviation and one gave me a 0 ohms reading and the rest were 3.9ohm<, so one bad and the others on their way out.
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
