Proved my point for me :sick:
So I'm sitting at home waiting for the Telstra people to come and install a line so that we can get TPG. Optus changed all their internet plans and they're absolute shit.
They said they'll be here between 10 and 2... but I'm tired, and slept like crap last night and really want a shower to help wake me up, but I can't, because I know as soon as I get in there they'll turn up and I won't hear them and they'll leave.
*sigh*
I hope they hurry up...
i bet they'll be tehre at like 1:45
hate shit like that - when they give you this window of like 4-6hours n you're like omg i have shit to doooooooo
Well... he's here... but not filling me with confidence... He calls the phone saying there's no one home. I open the door and there's no one there. Turns out he's in the unit complex next door...
:sick:
You do shift work ?
No, but I start early, and if I have done enough hours for the week (which I have) I can leave early on fridays :)
:sick:
LOL
It wasn't a black one by chance? With what seemed to be carbon fibre everything, and black (maybe nismo) 5/6 spoke wheels?
Yes. MIR34's the plate.
Anyone keen for lunch????
aaaannnd the Telstra guy just killed my Optus internet connection. Wicked.
If he is changing your phone line from optus to telstra, you should have expected that...
Alljap at Virginia for the indicator
Definitely lowball those mofos. Overpriced bastards...
3 hours to go. Kiwis installing 30 tonne props in the basement can't read a drawing. 750mm away from the end of the column so they put it 750mm away from the reo in the column = 150mm to close to the column = pissed off kiwis when I tell em they did it wrong.
Anyone else hear about Q1 sinking? Sounds like fun.
110 for a indicator!
they're like 40 on the forums man... i think i just saw one before
DOOOONT BUY IT YET!
ps nismo boy you around?
ugh gay icant find it
i found this which might be worth a go gts4 front cut
but as i said man around $40ish is what i've seen them for - so id bargain with the wreckers, (they're used to it), or wait and find one off the forums, or "i don't bargain because it's rude" and pay$110 :D
Probably overpriced, always are. Try All State Automotive it's in delta street, ask for Nick, tell him you know Ravi with the Maroon 33... he should be able to do better for you.
Ahhh man that thing is hell tough. Think he had some thermal coating done yesterday, not sure on the details though. Thermal Edge Coating is across the road from where I work... my boss and I heard a loud ass RB come tearing down the street..... then the high pitched squeal of an SSQV... *drool* so we ran out to see it pull in the shop.
I regret selling my SSQ now.
Anyway... yeah, that 34 GTR is off tits!
Edited by mosquitocoils
    • Resizing injectors in Nistune can be done a couple of ways, and there are a couple of ways that you can make a mess of it. The tuner needs to be really aware of the effects of whichever approach he uses (either K, or TIM). They are both easy enough to "get the injector size right" to run the engine. But little details like old start enrichment and hot start are affected differently, depending on which boxes you check.
    • Pretty safe to say almost everyone that has tuned their own car has experienced this issue. The difference being that we have our laptop in the car and when it happens, it's literally 10 seconds of tuning to sort it.  Would you be happy to plug in your laptop and sort this yourself? It is a very simple process and there is no risk of harming your engine (if you are worried about that).
    • Yeah thats the next step now, either they wil or i will take out for a drive to work and go straight their after work and see is we get the same issues 🤞  thought i try my luck here too, never know someone else might have had the same issue but thanks for the reply
    • Basically your tuner needs to drive it for the 30 min (or whatever) to create the same conditions then check the ECU settings and sensors at that time. They may not be excited to because that takes them 30 min rather than just opening the bonnet and seeing the problem straight away.... Hot start is generally not as tricky as cold start, but there would be a table for fuel enrichment vs coolant temp as a starting point
    • Yeah, they all cant say anything for sure as everything is working fine . Said unable to find an issue untill it stops again. Could mist likely be CAS wiring or IAS valve issue but again not 100%
