what tha eff?
google it. Get in a big blow up ball and roll down a hill. Terri asked me if I wanted to go and to ask "The Skyline Boys" if they wanted to come. So anyone in?
If by 31 ute you meant, say something like an X5?
Sure
I can paint a big "X5" on the bonnet if you like?
Nah, I tried phoning option 1 but didn't get a reply. Ended up taking it to Bosman Tyres. Roy noticed that the castor rod bushes were cracked, so theres another thing for the to-do list!
Ahh yep, I've dealt with Roy before too, he's a champion
Afternoon chaps...... nothing much to say
GTFO then :ninja:
i'm in if t!ts out
...do you have to walk up the hill? :ninja:
Hey bro got the stickers today . . . Thnx heaps :ninja: Ruv you Rong time :P
f**k dude thats quick - i only dropped them in the letter box yesterday!
wooo hoooooo :ninja:
X5? but why? M3 ftmfw...
E30 M3 is too old for work, I cant afford an E46 M3 out right and I refuse to get a loan and I don't think i'd be 100% happy with an E36 M3 (3.2 6spd spec).
I want an SUV, Range Rovers are too much for me to buy out right
X6??
Whats that? If I'm in Brisbane I'm in!
I'll come along to watch you all make fools of yourselves in the zorb..... and maybe rip some skids in the big field you go rolling down :)
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
