Lend me your eyes, oh posse!
I left work this afternoon, turned a corner (albeit somewhat sideways?) and went up the hill, never more than 65kmph... speed camera truck on opposite side of the road, on the side where traffic would be going downhill.
It flashed as I was coming up to it :D
Do you think its possible the guy inside set it off manually to get my plates etc?
OR is it more likely someone going the other way was speeding at the same time? Which side of the road/which way do they face?
EDIT: Yes, dumb, I know... shouldn't be doing stupid things.
Edited by mosquitocoils
They for the side of the road they're on - you should be fine.
OR - they take photos of the traffic going the same direction that their camera is pointing (usually the same side of the road they're on - but I've heard of some vans that have 2 cameras)
But I still think you'll be fine.
why did u want me to go home?
well... my car is driving like a charade, really need to put that goo on my coil pack. I was supposed to go to Jason's place to do it... but he's disappeared off the face of the earth... and I don't have sockets :D
Hmmmmm thanks for that... yeah I just hate the feeling in the pit of my stomach right now :D So dumb hahahaha ah well
well... my car is driving like a charade, really need to put that goo on my coil pack. I was supposed to go to Jason's place to do it... but he's disappeared off the face of the earth... and I don't have sockets :O
What do you need sockets for? Removing crossover pipe + coilpack cover etc? Or are you without coilpack cover? If you're without then you just need a phillips head screw driver... although you've probably thought of that already hahaha
unlucky. I can probably give u a lift if you need - call/sms me if you do as I'm about to p*ss off
It's driveable (just) so don't need a lift, thanks though!
removing strut brace, crossover pipe and blow off valve.
got allan keys and screwdrivers. Thought about trying it with my shifters, but it'd probably take me all fkn day
True where do you live? You can swing by mine and do it in my driveway if you want tonight?
That does not sound good
so, i finished work not too long ago, now im chillin here, just assembled my new snap-on air compressor, its a little oversized to say the lest.
I need a 15amp power point wired into my garage now......
It flashed as I was coming up to it :blush:
they can get you on both sides of the road. old boss got done by one with me in the car. camera was on the other side, flashed as he went past doing 70. got the fine two weeks later.
good luck. hopefully it was for someone on the other side.
That compressor looks bad ass :blush:
Don't the cameras have to point the same direction that the car is travelling though?
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
    • From memory it wasn't too hard to simply see which wire ran where when you plug that in. Unfortunately also from memory the OEM sender does not use the same configuration 99.9% of gauges run. So in other words if you connect the signal wire that was running to the OEM gauge to your DEFI gauge you might find your oil reads at 200C or some other incorrect value. I remember having the same line of thought and then running new wires/senders to match the gauges I have. The pinout is available in the R34 workshop manual.
    • Does anyone on here know which wire on the GTT triple gauge pod harness is for the oil temp gauge? my sensor works fine but I upgraded the gauges to DEFI advance. And if I can simply piggyback off the oem oil temp wire to the Defi oil temp sensor wire that would make life so much easier.
    • Even face her a wash now that’s it worth more than my house
    • This was what I was invisioning, or Pete cutting a beer can up and hose clamping it around the catch can! Ha ha ha
