Lend me your eyes, oh posse!
I left work this afternoon, turned a corner (albeit somewhat sideways?) and went up the hill, never more than 65kmph... speed camera truck on opposite side of the road, on the side where traffic would be going downhill.
It flashed as I was coming up to it :D
Do you think its possible the guy inside set it off manually to get my plates etc?
OR is it more likely someone going the other way was speeding at the same time? Which side of the road/which way do they face?
EDIT: Yes, dumb, I know... shouldn't be doing stupid things.
Edited by mosquitocoils
They for the side of the road they're on - you should be fine.
OR - they take photos of the traffic going the same direction that their camera is pointing (usually the same side of the road they're on - but I've heard of some vans that have 2 cameras)
But I still think you'll be fine.
why did u want me to go home?
well... my car is driving like a charade, really need to put that goo on my coil pack. I was supposed to go to Jason's place to do it... but he's disappeared off the face of the earth... and I don't have sockets :D
Hmmmmm thanks for that... yeah I just hate the feeling in the pit of my stomach right now :D So dumb hahahaha ah well
well... my car is driving like a charade, really need to put that goo on my coil pack. I was supposed to go to Jason's place to do it... but he's disappeared off the face of the earth... and I don't have sockets :O
What do you need sockets for? Removing crossover pipe + coilpack cover etc? Or are you without coilpack cover? If you're without then you just need a phillips head screw driver... although you've probably thought of that already hahaha
unlucky. I can probably give u a lift if you need - call/sms me if you do as I'm about to p*ss off
It's driveable (just) so don't need a lift, thanks though!
removing strut brace, crossover pipe and blow off valve.
got allan keys and screwdrivers. Thought about trying it with my shifters, but it'd probably take me all fkn day
True where do you live? You can swing by mine and do it in my driveway if you want tonight?
That does not sound good
so, i finished work not too long ago, now im chillin here, just assembled my new snap-on air compressor, its a little oversized to say the lest.
I need a 15amp power point wired into my garage now......
It flashed as I was coming up to it :blush:
they can get you on both sides of the road. old boss got done by one with me in the car. camera was on the other side, flashed as he went past doing 70. got the fine two weeks later.
good luck. hopefully it was for someone on the other side.
That compressor looks bad ass :blush:
Don't the cameras have to point the same direction that the car is travelling though?
    • Thanks. We getting some parts along too so he will be solving the speed issue like next week so i will let you know what he came up with.
    • 21 is explicitly the coils detected as the issue. Is it guaranteed the actual issue? No. Just the ECU thinks it is. When you say rattling, describe it better, get an audio clip as best you can if possible.
    • Yea got me coppers. Bad news is I just put them in and the car still has the light and shakes. I also noticed I hear like rattling coming from the exhaust piping right under me. Does 21 also have a possibility of being O2 sensors?   So, coil packs are good, the harness is good, the MAF is working, and obviously the spark plugs just replaced and working.
    • Make sure you drop the GTT base tune back in, and set your injectors again, this will remove anything playing up with it you may have removed. Possibly lean there as it's normally a fast transient going THROUGH atmospheric pressure, and a turbo motor would then quickly go richer as boost builds. The only worry you MIGHT have is ignition timing, as the DE is higher compression than the DET from memory. But again, you're not in boost, so the DE motor will be a lot more forgiving at atmospheric.   Get Murray, Kinkstahs, and Johnny's input on tuning haltechs, those guys have played with tuning enough in the past to be able to help now you're past the trouble shooting stage of the MAP issue
    • @Rusty NutshI mate. Do you have a pinout diagram for the na neo auto ecu?
