so, i finished work not too long ago, now im chillin here, just assembled my new snap-on air compressor, its a little oversized to say the lest.
I need a 15amp power point wired into my garage now......
f**k. yes. :blush:
Big thanks to Ravi for letting me use his tools tonight!
And a big thanks to Dan for helping me ditch my valley cover!
All good mang :D Glad you got it sorted.
And everybody who didn't come tonight didn't get to see Colin's new Skyline!!
But here's a pic anyway:
Needs more RB
Don't the cameras have to point the same direction that the car is travelling though?
They can set em up however they want. Sometimes it depends on the road n shit how they set it up but they can get you going both ways, coming towards, going past etc.
needs more low :D
What you talking about its on its rails!
Neggo
Car gone?
11:20am, the sphincter of the universe no1. when the cat is away, i will get hammered before lunchtime...
Definately quote of the day
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
