my lunch was good, aside from the fact that a work mate spilled 2 schooners in my lap....but i got to come home so i guess that was win after all!
Spilling beers on your mate . . . 1 star
ohk ohk well so we dont match ill go for shallow ocean blue turtle neck with a pair of arctic ice shelf pants
when we are out i can get a 6pm winters sky navy scarf to compliment turtle neck
<3 Dudeman
THAT IS SO SIG'D
I just saw what appeared to be a very very worked NA 180 on Maundrell Tce/Hamilton Rd. White one, with rims like Josh's but not as much dish. Tristan, you probably would have jizzed buckets.
jizzed buckets . . . . lolz
So, big thanks to Andy for pointing me to that thread. It's working now, and if it stops working again, at least I know how to fix it :)
good stuff!
i want jackpot noddles however cbf walking into the city, and i only have another 45minutes until next class ugggh
i was at jackpot in the city at 1pm having lunch. should have legged it over, could have shouted you lunch on my work account ;)
and on a side note, i finally got some injectors.
sard 550's arriving next week sometime, so just a matter of getting a z32 afm, and then installing the rest of the go fast bits ;)
sard 550's arriving next week sometime, so just a matter of getting a z32 afm, and then installing the rest of the go fast bits :)
fuck yeah, Miso. ;)
Fuck yeah.
f**k MAN!
ugh that would have been awesome
oh yeeeh - ive been waiting for this for over a year, at least
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
    • From memory it wasn't too hard to simply see which wire ran where when you plug that in. Unfortunately also from memory the OEM sender does not use the same configuration 99.9% of gauges run. So in other words if you connect the signal wire that was running to the OEM gauge to your DEFI gauge you might find your oil reads at 200C or some other incorrect value. I remember having the same line of thought and then running new wires/senders to match the gauges I have. The pinout is available in the R34 workshop manual.
    • Does anyone on here know which wire on the GTT triple gauge pod harness is for the oil temp gauge? my sensor works fine but I upgraded the gauges to DEFI advance. And if I can simply piggyback off the oem oil temp wire to the Defi oil temp sensor wire that would make life so much easier.
    • Even face her a wash now that’s it worth more than my house
    • This was what I was invisioning, or Pete cutting a beer can up and hose clamping it around the catch can! Ha ha ha
