Is that Nick's dirty-one? I don't remember it having a TI bonnet...
lurker...
yeh nicks 31, and no not a lurker, link got sent on msn :D
YEH MSN
THE THING YOU NEVER TALK TO ME ON
ROOUUUGGGHHHH
ps sup guys
I'm at work you douche
I'll get home and have messages from you but you will be offline coz you are a dog, and I won't bother replying coz I know your failBook won't receive the offline messages
so just get a PC :D
@John
Well i was waiting to put the new TE37s on it and the new engine bits before posting pic but who knows when that will be...so
<3
Sounds good man :P
Yeah will be WHEN MY DAM PARTS ARRIVE!!!! lol Fedex rang up again today and they've been delayed once again till Thursday, that'll make it a month since I order and they still haven't arrived! :no: Hopefully I'll get them soon
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
    • Yeah - I mean, go the other way. Smaller range. Not larger.
