hopefully they all kill each other off.
now - if anyone ever thinks that they've had the world's greatest page claim... I put it to you sir/madam, that only did you suck off a horse... but... I fucking win
Truth.
P.S. Fap
Edited by Smity42
re zombie champion...Vampire wins, Vampires cannot be infected by anything they are effectively immune to all viruses ect, also if the vampire in question is Vlad Von Carstien he could not only hack the zombie to pieces but then re animate it again to join his side as he is able to perform necromancy :D winner!
Yes but ever since twilight... Vampires are gay
Von Cartiens will NEVER be gay, im thinking about a movie where the Von Carstiens destroy the cullens just because they can
Twilight has no vampires in it. Go out in sunlight, don't kill humans, drink animal blood. They aren't vampires. I'd have to go with Andy on the Vampires > Zombies. They can't be turned into Zombies because they are already dead. Vampires are essentially zombies without the mindlass rage/stupid BRRAAINNS mentality.
That is not completely accurate though. The scenario we are discussing is a 1 vs 1 death match. The fact that some humans would be able to kill 1 zombie means it would be a cakewalk for a vampire. Quote from the article link
Vampires are strong, but not invincible. The Zombie Survival Guide estimates that an average human can fend of 8 to 9 zombies. Assuming vampires are at least 10 and at most 50 times stronger than humans, then a single vampire could fight off between 80 to 450 zombies.
Zombies are fine if they are attacking in numbers but 1 vs 1 they are pretty pathetic.
    • Shouldn't need a "base map" for anything other than guidance to ignition tuning. You just need the engine capacity right, the injector size right, and something, almost anything, for a VE map. On an NA engine, fuelling is almost completely a function of load signal & rpm. It should run and drive with a completely flat fuel map. It will be too lean under load, but that's easily fixed. We used to tune all ECUs without any base map. There were no such things (until someone had tuned a near stock engine on one, and then they had a "base map".
    • What did you actually buy/how much did it cost? When I got mine in like.. 2017...? 2019? the aim was to run Torque for gauges via ODB2 and things like Track Addict/Laptimers/Dashcam/Reversecam/Spotify etc. Mine never broke, but I wonder if you've got the same needs (it sounds like it). Cause I liked the idea of being able to do anything with it. That said, yours also cost 3x the cost of what I spent so... food for thought.
    • For me there is a massive difference in manufacturer or big brand crippled android (Sony, Kenwood etc) vs the sort of thing I've installed here, which is basically just a tablet in DIN form factor with open Android, and the other model of course is mirroring - Android Auto/Carplay. I hate the locked down manufacturer and AA options where they decide what apps I'm allowed to install, including the Launcher but also importantly things like Ecutek (for this car) or Real Dash (Stagea) are not supported. Plus those crippled versions tend to be slower due to both overheads and lower spec hardware. On the other hand, when this breaks I'll likely be in trouble for support....but how is that different to owning an Infiniti anyway
    • Yeah, Duncan is helping sell me back to Android devices. I've hated the whole Android head units due to their speed issues. Even in my old Hyundai Kona (2022 model), it behind the scenes was Android, and slow and shitty to start up. Once running wasn't bad, but still a good 15 to 30 seconds.
    • My roof rails are off atm on the E39 until the rust is fixed. I did find another little bit of surface rust under the rails when I took them off. As @soviet_merlin said I'd just leave them alone unless you're planning on ensuring they're properly sealed. I was on the fence about leaving them off as the delete is still a thing in BMW E39's but I feel like the car is missing something (er, it is, der) with them off and I'm looking forward to putting them back on.
