just booking the accommodation now. hoping to catch a few nba games while i am up there.
youd better hurry! The regular season has only about 5 games left for each team! NY (sadly as they are my team) will not be in the playoffs so no games going on there...but LA will be so you might be able to catch one of thier games and hang out with Jack Nicolson
Oh and Morning all!
16 is heaps legal
and she is ugly as f*ck too so she is probably keen for attention and being so young doesnt know the difference between good and bad sex, im starting to see the appeal, but still she is a horror
why does every one keep posting pics of that ugly, 12 year old boy bodied, ranga?
:laugh:
16 is heaps legal
+eleventy
hmm, all out of toilet paper.....
handy wipe, or coffee napkins with colourful print on them
decisons decisions
colorful print fo' sho'. at least that way you can fool your mind into thinking it's still TP
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
    • This. The R34 handbrake icon DOES come up when the brake fluid level is low. You might be sitting right on that threshhold. I have been down this diagnosis path and this was the solution (and it was pretty much as full as your picture is to begin with).
    • Unfortunately the cavaet to that is that while any scan tool should be able to read the code, the workshop will need a consult plug to OBD socket adapter. You don't have a location on your profile, where are you based?
    • @Haggerty this is your red flag. In MAP based ECU's the Manifold pressure X RPM calculation is how the engine knows it is actually...running/going through ANY load. You are confusing the term 'base map' with your base VE/Fuel table. When most people say 'base map' they mean the stock entire tune shipped with the ECU, hopefully aimed at a specific car/setup to use as a base for beginning to tune your specific car. Haltech has a lot of documentation (or at least they used to, I expect it to be better now). Read it voraciously.
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
