and for the rest of the thread:
Happy birthday Josh and Tristan
I'd probably go along to wherever you're playing football to watch/socialise/eat food while you all run around.
Good luck with the roadworthy ravi. Bring it to BR so we can check it out. And bring some bitches for Martin. There's only so long he can watch through the window before they get a restraining order.
get your tractor fixed thristian?
Yeah I reckon somewhere northside but closish to the center of town is your best bet for footy
yeh mate got it all sorted - gasket fitted, front pipe replaced :) - the jap front pipe fits sooo much better than the cheapo china one that was in it
Martin these are the wheels I have at home. They came off my 33 when I bought it. No idea on offsets but I'm pretty sure they are 8.5 wide. Are these the same ones you were talking about last night?
edit: mine are 17s aswell. the ones in the pic are 16s
zomg sell/give me a pair?
Happy birthday Tristo...
The laser's having a roady done today so fingers crossed hahaha!
thanks sexy
excited for car trips next week?
so, when we're playing with pipes :D
pipe work is done - i think i want twin pipes, im 90mm under the car, but the cannon puts it at 70mm - twin pipes would fix that and look uber lolzz
Yeah happy birthday Tristan!
And happy birthday for yesterday for Nismoh!
<3 :ermm:
Yeah forgot about that. Happy birthday Josh n Tristan ;)
i wnat to touch you
Well it phailed miserably. Got a list to look at, usual crap like brakes, seals (oil leaks etc), one tyre blah blah blah... most of it I should be able to do myself, but rear main seal? Really??? Never taken a box off before, but I'm willing to try... opinions anyone?
Also front and rear link pins? Don't even know what they are lol
pipe work is done
i wnat to touch you
gearbox rear main seal? f**k man - front wheel drive boxes are a joke
replace the tyres and brake pads, and degreze the engine bay then call me :)
no idea wtf link pins are :ermm:
no idea wtf link pins are :)
I had link pin suspension on the front of my '73 bug. The '67 had link pin front and rear.
That's probably what they're talking about.
this is what the front of my bugs used to have:
Does the TRD Laser have something similar?
Edited by Isola
I wish!! f**k I want a dune buggy now!!
So I found out it was the link pin bushes (ends of the swaybars) and a kit for the front or rear is like $20... so I have one and will attempt it this weekend, should be a piece of piss.
Got the brakes too and all the other little things like the clutch rubber thing, nice solid battery clamp wah wah wah.
And yeah I'm gonna degrease the underside around the rear main seal, but the front crank seal + belts, idler blah blah are all gonna get swapped anew when I get some spare cash in a week or two, and that should see me pass roadworthy as the front crank seal + cam seal were the worst offenders for oil leaks. No so keen on doing it myself.
you REALLY want to run spacers on a track car? :)
Yes, hub centric bolt ons a perfectly safe. In fact, CAMS rules state you can have 1 spacer behind each wheel.
Just queensland transport that are gay
well sweet as then :) let's go put some cars up on bricks :)
dude hit the engine with degreaser and the next day take it back, or take it to a different place :)
Yeah I could do that, but at the same time this car will keep going forever after a bit of TLC, so I might as well do it right the first time.
That's so unlike me, I'm always about the quick fix, just get it good enough.... what the f**k's going on!!
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
