I think you need to get me a job working with your company :)
Join the Navy you get to play ships..... literally
http://www.news.com.au/national/navy-sinks...r-1225859697498
I like that song. Whatever happened to him ?
Morrison later was incarcerated for a year for paying a lookalike, to perform Morrison's court-appointed community service in Morrison's stead.
Hey Martin or Jason:
Any chance one of you wants to go to Baskins via my place tonight and pick up two of my S15 rims for me? Got a dude coming to buy them at Baskins (he lives in Ipswich so this makes it a bit closer) and If I put all 4 of them in my car at this height I'll be riding on rails at the rear.
I'll pay for Icecrem for whoever helps with my new found wealth from wheel sales :)
I'll pay for Icecrem for whoever helps with my new found wealth from wheel sales :D
I'll come past and help out...
whats your address again ?
my apologise for not attending tonight. My car was in desperate need of mechanical work i have been putting off for about 3 months now and the fact that i am once again heading west this long weekend makes it kinda requirement to replace this urgently.
I also hear martin has issues with his high beams flickering on.....
f*ck the police
EDIT: I wonder if they defect everyone for a faulty high beam, or just imports?
See if it's in the legislation somewhere. Be worth getting it overturned if you can. Get your point back :merli:
Train line, Low cost housing (Yeah right) and shops
Will be low cost eventually. Prices can't be sustainable as they are.
f*ck the police
Douchebag for sure
you got defected for a flickering high beam?
ridiculous
fine, fair enough, but defect....
Yeah intermittent flickering of high beams after passing a speed camera. It was very mysterious :merli:
even sneakier. but still. a f**king defect. what a joke. how did they catch you? were they just randomly stationary afterwards, or sitting there waiting for people to do that?
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
