Mine are good compared to driving with parkers on. That's about it lol.
niggah prease. I could see just fine with your lights on, and my lights OFF.
Don't expect to hear from him till monday night
Yeah I know, but was leaving it there for him to find. Turns out there's no such thing as a filter and ERD Dan thought I was on drugs. Quick phone call later he thinks my abs has raped my 4WD. Need to check sensors.
300HP out of the 20 should be pretty easy. Will only stop my nightmares if I don't ever have to do any work on the Z32.
Suggestions for reaching power target? I did so much research on VGs that now I don't know what to do with my RB.
NO work on it? What if it needs a bangin' stereo? :(
Who's Michelle?
Someone Tristan and I have both worked with
What toys?
These squeaky toys :P:D
yo
i got rid of my original lights (inc bulbs.) when i bought the blue ones
the bulbs in the original ones were those bluey ones they sell at repco for stupid expensive prices (for what they are)
my new bulbs are 100w ones (stock is 60w) - they are sexy, overnight parts from hongkong lol
@p.s. - yeh sure
@p.p.s. - yeeh had to dog - needed to pick up copper nut, and that involved a trip to manly lol
Think mine were hungee wottas too from memory. Probably using the same (or close to) what I used to have.
sweet :rofl:
what was Colin doing at Manly? :P
Edited by Isola
soooo......
Avatar is a complete piece of boring ass shit. Only good thing about it was getting to see that silly mole Michelle Rodriguez die again. Predictable rehashed phone in hack of a movie.
How do I go about getting back the 2hs 41mins of my life? Does anyone have a flux capacitor?
euro disney epic fail
waste of $140 in entry fees. in terms of rides, movie world or dreamworld rate higher
anyways, it's 1:30 am, and i gots to be up at 5am for our flight to new york. shall have a look for a mets hat once there.
will have net at the hotel in ny, so shall annoy you farkers some more
peace out
soooo......
So glad I refused to ever watch a 3D movie about blue fairies, I'm going to use that 2h:41 and put it to good use....drinking
@ Andy:
What was the name of that RB management system that you were raving about a while ago that allows you to run without AFMs? Could I use it on my 20? And will it handle what I just said to Colin & Martin?
Adaptronic, though they are better for 4cyl applications as the e420c only has enough drivers to run a 4cyl in sequential spark. they have a e1280s now but i think it is around the same price as a vipec ect, the main advantage of a e420c was the pirce. it you are happy to run wasterd spark though the e420c is still a really really good computer, my old r33 is running happily on one
Yeah, I would never have watched it if the GF hadn't. I got bored a few times and went off to make coffee and things, so it probably doesn't owe me the full 2:41, but pretty close :)
Thanks Andy. Don't know why I thought it was an RB one. I'll keep on the hunt :)
vipec ftw
Cheers - I'll read up on them :)
btw - does anyone know how much mines ECUs go for for the 32? I got a dude wanting me to make him an offer on his, and I have NFI how much to say...
0$ they are for jap fuel and are really only useful to get rid of the speed limiter
Is that really the only benefit from it? What if it's mapped for Aus fuel?
you cant remap them, the eprom is covered in about 3 inches of epoxy so it cant be swapped out, the benefit is that on jap fuel they give you slightly better fuel and ignition maps and move the rev limiter and speed cut and the richen and retard part of the standatd ecu. But in Aus all it does is make the car run lean.
ok cool, thanks again :)
I'm reading up on Vipecs, but it's making my brain hurt. So much info!!!
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
