yeah, I'd remove that split pin or it could get pretty messy.
bring the two "split ends" together with screwdriver/pliers whatever (so it's straight again), then pull it out from the non split end
One of us is tripping balls, because I see no split pin in that photo :S
Dumb question - how does it remove? Pry the squashed bit up with a screw driver.... then what?
Ravi, it look to me like that squashed bit is the equivalent of the split pin, ie it stops the nut spinning. Once you pry it up with a screwdriver so that it will no longer interfere with the nut spinning, you should be able to take the nut off in the usual fashion.
Unless of course there IS a split pin, then you'll need to remove that as well.
just checking in
Touge?
1
2
3
BINGO
That's what she said
Pfft. You would.
Pfft. You would.
Morning Mang. And other Mangs. And Colin.
Keen?
Always
I wish
Gonna go down to the TRD garage and check the status of said split pin right now.
Ahahahaha 'and colin'.
Morning.
And purged for 8?
Split pin is split. If that's what it is. Stuck on there harder than.... well..... you get the idea
Always
I wish
Morning.
Quiet you :D
Waxing.
You?
Fapping obviously
first day back at work today, after 6 weeks off.
so so ghey
That has to suck balls.
I look hot in my little v neck sweater today
Pics or GTFO
I stopped eating for 5days
Pfft only 5 days..
And purged for 8?
Ahh, I think I see what may be a split pin now. Hard to tell from that pic. Demand MOAR pics, high quality.
Yeah I don't think it is a split pin as such more of squashed something over the bolt. Flat blade screw driver or some long nosed pliers would be my guess and try to pry it apart. If nothing else works set it on fire.
Fire solves all, I hear.
Screwdriver didn't work. Just bent the ducker lol. Will try needlenose pliers this arvo I guess. Sigh.
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
    • I said Garrett style. Not Garrett genuine. And something in the G30 550 range is what you want. Not those pokey little old fashioned T28 sized things. The intake ports in the head are small. There is little benefit in fattening up the runners and leaving ths actual ports small. Just run what you've got. And on the subject of Nistune vs Haltech etc..... You know you can control the transmission with decent standalone ECUs these days, right? No need to keep any of that old Nissan bullshit. Don't get me wrong - I use Nistune on my Neo. But it is a DET, so the number of bodges and workarounds I had to do to make it work in a chassis without ABS, TCS, etc, is quite small compared to the herniated arsehole you will have trying to make it work on a motor that doesn't have some of the things that the turbo ECU wants to see. Just easier to bite the bullet and go aftermarket outright.
    • Hmm. Only when the f**king thing is actually working. Still can't find the leak. And that's with dye being put in the last 3 times!
