You are clearly referring to a trial, where Colin in an exhibit in a rape case.
You sir, are correct sir.
:wub: I am one sexy motherf**king Ranga :bunny:
Also guys... What does a f**ked engine mount/s sound like? My mates mx6 is making noise when accelerating or turning right & accelerating at the sane time, but doesn't make the squeaking/rubbing noise when travelling out of gear, and it doesn't appear to be suspension or motor related
more like - what does it FEEL like. Hektik shudders that you can feel through the firewall when the car is idling is usually a giveaway. Similar to power steering shudders, but more hardcore.
more info on what it sounds like?
Mm yeh no shudders at all... Sounds kinda like a belt or low pitched rub or scrape. Not very loud but notoceable. His battery died 2 months ago so I just suggested alternator area, maybe the pulleys loose or similar? Or a bearing on it?
timing belt cover isn't rubbing against the belt is it?
