Pizza capers pwns Hells, its not even close IMO
+1
Hell Pizza is crap. And so is that Earth & Sea bollocks
Capers > Hells AINEC
They are different style of pizza. Hell is the best of the fatty 'fast food' style pizza, which I happen to like (as previously mentioned, I lived on it for 6 years :down:). Capers is a bit more 'gormet'. I refuse to rate one above the other, I like them both.
I remove the thumbs down as they are good pizza's
Good.
Then there's no debate at all. Pizza Capers FTW.
;) but still going to hell's pizza tonight as it's practically a drive through on way home.
Damn you. No practical Hell for me ;)
Hotties + Pizza? New destination for thursday night meets?
While good, they do not even come close to comparing to the JB buffet on offer at baskins
Sarp Mangs. Hot new graduate started today. It's awesome.
Nice. I feel we are overdue for a new hot admin trainee here actually...
picsormuthafarkinban
+1
ill see what i can do
do or do not, there is no try
I've just started my engineering course... If thats anything.
techincally I would call that something, in the same sense a bush that I drive past is also techincally something.
it's not really of interest to me, but it's something..... it's there
Give me some good music to download, mangs.
John, these are the highlight albums in my recent playlist, not sure if there's anything in there for you but at least I tried
Death cab - narrow stairs (wishy washy ambient "emo" but great)
Death cab - plans (better than above, very introspective)
Every time I die - the big dirty (screamo/metalcore)
Steve aoki - pillowface and his airplane chronicles (dirty electro/house)
Bury your dead - beauty and the breakdown (metalcore)
I get my gauges mounted up on friday
I'll mount you up
Thanks man. I'll check out the ones that aren't electrofaggotry
    • Messing around with. Twin kit for. Rb30/26
    • For fuelling the Haltechs have O2WB fuel controllers. Very useful for helping tuning VE and correcting for *small* mistakes. Of course if your injector/cam/trigger/sensor data is just wrong (or for a GTT which is not a GT) then you will get impossible reactions to things. I am sure you know this already but the reason people don't typically put haltechs (or any Aftermarket ECU) on GT's is because there's practically no real gains to be had - So this knowledge won't be commonplace.
    • Can someone tell me if the cracks seen in the rear sway bar bushings in these photo's is unacceptable from a roadworthy point of view?
    • Shouldn't need a "base map" for anything other than guidance to ignition tuning. You just need the engine capacity right, the injector size right, and something, almost anything, for a VE map. On an NA engine, fuelling is almost completely a function of load signal & rpm. It should run and drive with a completely flat fuel map. It will be too lean under load, but that's easily fixed. We used to tune all ECUs without any base map. There were no such things (until someone had tuned a near stock engine on one, and then they had a "base map".
    • What did you actually buy/how much did it cost? When I got mine in like.. 2017...? 2019? the aim was to run Torque for gauges via ODB2 and things like Track Addict/Laptimers/Dashcam/Reversecam/Spotify etc. Mine never broke, but I wonder if you've got the same needs (it sounds like it). Cause I liked the idea of being able to do anything with it. That said, yours also cost 3x the cost of what I spent so... food for thought.
