Indeed I did good sir. Parkway Drive one was pretty good. Sea of Treachery, I'll have to listen to a bit more of. I listened to Unleash The Serpent and that one was good! The other one - the mordecai thing. I like the third part of the song, not the brutal bit, not the dude just singing with his keyboard, the ... outro I guess you could call it. When it went all awesome guitars and vocals. Dan has given me so much stuff to listen to that I'm having trouble keeping up with it all! Still a couple of bands I've downloaded entire discographies of and haven't had a chance to listen to one song!
Jay Jays don't sell jeans I like. They sell those 'faded' things. I just want dark blue denim. If they fade they fade, but I don't want pre fade.
Isola is a Swedish word. There's no direct english translation for it. It's closest translation is "isolation" but it actually means the kind of isolation more related to an island than just being isolated from people.
Save up your pennies and buy some dry denim jeans if you like em unfaded.
Blue>black
Unless it's your girlfriend/wife, in which case both colours are acceptable at the same time.
Not when the blue ones are faded to buggery. But hey, this way, if I wear a black hat and jacket and cover enough of my cracker skin, I can buy fried chicken :D;)
If I have to save for them, then they're too expensive. Big W ones are unfaded, and don't require saving :D
Fair enough.
Jeans aquired. Bought black ones this time instead of blue ones.
Black ftl. No racist.
I have white skinny jeans. I do not look like a fag in them, at all.
also spotted Dan in some homo as CRV near James St
I'm sure you don't lol. I've got a pair of skinny jeans an ex bought me ages ago. Wanna buy em :D they'd probably fit you.
I have many skinnies... My joke was towards me also having white ones.
What size are they fatty ;)
I have white jeans like pants, they have RM Williams on them though :D
What size are they fatty :D
30s or 32s. Probably be loose fit on you lol
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
