I could probably help out with the other half bar?
I don't know what to do with that one...
"That's what she said"
"I'll bet you can"
"Unload it by hand?"
etc.
too many options :laugh:
Looks like a poofta's motor
So gay cowboy approves then?
Col you should buy another 31 coupe?
I'm looking for a stock GTS-R in japan now actually as my next rb26 project... :laugh:
Got another r34 gtr engine sitting here waiting for a body to impress...
I always wanted an rb26 RWD GTS-R as a fun car...
Old man was considering writing a letter of complaint
I felt like yelling at them to step away from the coffee machine and "f**king serve me"
I was there for 15 minutes with not one word spoken to me, then when i sat in an S4 I had two salespeople fight over who was going to serve me first...
Then once I got both salespeople working selling me a car in tandem (very uncomfortable i might add) they talked to each other more than me...
I ended up just saying, "Im going to buy a car, but it wont be from here" and both turned their noses up at me and I left...
They returned to their coffee machine and went back to doing sweet f**k all...
I thought about calling the dealer principle but then after going to Lexus I didnt care anymore, as i was not going to buy an S4 after all...
Upside is if they were not rude and give poor service I would have never know about the Lexus's...
...you let her speak?
She said she was not satisfied with making sandwichs for everyone else and all she wants is a cock meat sandwich...
I do find it funny that car sales people are how they are. Fact is, they earn like $500pw.
As you know Josh, im in sales and have been for 13 years now...
You cant sell a salesman the dream... You can only answer the questions and point out the benefits...
I personally found all the car salesmen I spoke to quite in-experienced and very poor salesman ship...
All the good sales people in this world dont work for car dealers, there too busy making money in a real industry...
Just upgraded to full bar
I did a rb26dett GTS-X many years ago...
Just did a stock motor from an r32 GTR, with some sump mods and a pfc and thats it...
Jesus it was fun to drive, just want to do a similar setup this time but maybe with a few extra horses...
Got an R34 motor here with N1's, Z32 AFM's, injectors and cams ready to go... Internally stock/original otherwise...
Jut wack an pfc on it and way we go... Just trying to find the right body first and the GTSR sounds perfect as their quite special in my books...
This more than makes up for the euro faggotry
oh I am... I am
Col, if you find a stock r31 GTSR and then 26 it the RB gods will remove a testicle and shorten your penis.
Live in fear.
Live in fear.
It won't be the RB Gods, it'll be the amount of boost causing them to recede!
ignore phone .... problem solved.
Anyway chaps im out for the next couple days, heading west again, will be back here on monday night. I'll try landing me a pig this trip.
surely the girls out west aren't that ugly...
even god knows rb20s are shit
Col, if you do find a stock GTS-R i will buy the turbo manifold, heatsheild and turbo from you from the RB20DET-R
im looking at three at the moment all with epic engine damage...
i just want a straight body & something that can be registered thats all...
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
