I could probably help out with the other half bar?
I don't know what to do with that one...
"That's what she said"
"I'll bet you can"
"Unload it by hand?"
etc.
too many options :laugh:
Looks like a poofta's motor
So gay cowboy approves then?
Col you should buy another 31 coupe?
I'm looking for a stock GTS-R in japan now actually as my next rb26 project... :laugh:
Got another r34 gtr engine sitting here waiting for a body to impress...
I always wanted an rb26 RWD GTS-R as a fun car...
Old man was considering writing a letter of complaint
I felt like yelling at them to step away from the coffee machine and "f**king serve me"
I was there for 15 minutes with not one word spoken to me, then when i sat in an S4 I had two salespeople fight over who was going to serve me first...
Then once I got both salespeople working selling me a car in tandem (very uncomfortable i might add) they talked to each other more than me...
I ended up just saying, "Im going to buy a car, but it wont be from here" and both turned their noses up at me and I left...
They returned to their coffee machine and went back to doing sweet f**k all...
I thought about calling the dealer principle but then after going to Lexus I didnt care anymore, as i was not going to buy an S4 after all...
Upside is if they were not rude and give poor service I would have never know about the Lexus's...
...you let her speak?
She said she was not satisfied with making sandwichs for everyone else and all she wants is a cock meat sandwich...
I do find it funny that car sales people are how they are. Fact is, they earn like $500pw.
As you know Josh, im in sales and have been for 13 years now...
You cant sell a salesman the dream... You can only answer the questions and point out the benefits...
I personally found all the car salesmen I spoke to quite in-experienced and very poor salesman ship...
All the good sales people in this world dont work for car dealers, there too busy making money in a real industry...
Just upgraded to full bar
I did a rb26dett GTS-X many years ago...
Just did a stock motor from an r32 GTR, with some sump mods and a pfc and thats it...
Jesus it was fun to drive, just want to do a similar setup this time but maybe with a few extra horses...
Got an R34 motor here with N1's, Z32 AFM's, injectors and cams ready to go... Internally stock/original otherwise...
Jut wack an pfc on it and way we go... Just trying to find the right body first and the GTSR sounds perfect as their quite special in my books...
This more than makes up for the euro faggotry
oh I am... I am
Col, if you find a stock r31 GTSR and then 26 it the RB gods will remove a testicle and shorten your penis.
Live in fear.
Live in fear.
It won't be the RB Gods, it'll be the amount of boost causing them to recede!
ignore phone .... problem solved.
Anyway chaps im out for the next couple days, heading west again, will be back here on monday night. I'll try landing me a pig this trip.
surely the girls out west aren't that ugly...
even god knows rb20s are shit
Col, if you do find a stock GTS-R i will buy the turbo manifold, heatsheild and turbo from you from the RB20DET-R
im looking at three at the moment all with epic engine damage...
i just want a straight body & something that can be registered thats all...
