Also the F430 Scuderia pulls harder then martin at a baskins' meet
lol lol lol
Anyway chaps im out for the next couple days, heading west again, will be back here on monday night. I'll try landing me a pig this trip.
<3
Morning mangs
Scarnon
Engine should be on the way to me soon :)
AHAHAHAHA I lol'd hard
surely the girls out west aren't that ugly...
Maybe not but the pigs are RRREEEAAAALLLL purty....
EDIT: FUCK YOU SAU COP/PIG FILTER!!!!!
even god knows rb20s are shit
Especially redtops.
LOL John, good form
Edited by Smity42
Sup mangs. Bus at 5:50am to get to uni for 8..gaids. So after about 10:30 today I have nothing to do until baskins. Help?
Go hang at baskins all day? I'm sure if you're there for that long you can manage to hook up with at least one of them :)
So what you're saying is, you can't get yourself wet like a flood...
Thats what it sounds like to me.
If you're not making a mess, you're doing it wrong...
Im not much of a flooder..
However it does make it easy to have a quick play throughout the day..
Hahaha, Dont get me wrong.. I love, and am all for getting messy..
But sometimes it's good to be able to have a quick flick and move on lol
Def makes it easier to finish the day off.. Especially at work..
Efficiency = Win?
    • Update: tested my spark plugs that are supposed to be 5ohms with a 10% deviation and one gave me a 0 ohms reading and the rest were 3.9ohm<, so one bad and the others on their way out.
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
