I declare F-Duct drinking game a success! I am nicely munted, and that was only qualy :)
I am thinking of introducitng a bonus round of some sort for vettel being a tool... details still to be worked out :D
my everything hurts.
Was having a jam session at a friends girlfriends house, in the room we were in theres a pillar that runs across the ceiling and being a tall bastard and all, I have multiplied my hangover by walking into it.
I am thinking of introducitng a bonus round of some sort for vettel being a tool... details still to be worked out :blink:
Drinking game.
Sign me up :(
What job do you have which requires work on a sunday?
I make sure you have water coming out of your tap in a nice controlled way.
Not like that.
Like this.
I made some light progress on my project car, i cleaned the garage, then realised i can't actually do anything i wanted to do this weekend cause i need to get the guards lipped before i can put the coilovers back in. And that the coilovers need new pillowballs and heavier springs. Hopefully will sort that for next weekend thought.
This arvo i started sanding back panels and getting them ready for the primer coat.
Sounds productive. :blush:
Whats a pillowball :happy: ?
sure are, they are my upper shock mounts, also known as Spherical Bearings. I'd really like to get brand new ones but i don't know where to get them from.
In other news, only a couple days until i get awesome pints'o beer and lamb shanks!
Whats a pillowball :blush: ?
I've got two in my pants, if you'd like a demonstration?
So much win! Gonna go for the pork knuckle!
Anyone know/recommend a good detailer on the northside? Mate wants his car done inside and outside before he sells it
Always you know that :blush:
Ask Sabbai.
    • Did you take the MX5 for a Blat around the Track at all?
    • LOL, "they said it might be slippery"..... 30 seconds in your off, 60 seconds in white twin backs into the corner That new track looks good, and the Datsun was chopping cars quite nicely
    • I'll get one of these also just for giggles
    • I bought 6 new spark plugs to compare readings. They will be here tomorrow and ill see if meter is far off if it all. I know one is at least reading 0 so its best replace all anyway if one is bad, from experience. I still have to test the harness just to be sure its not a double issue and I waste my time haha-the old plugs are iridium I always thought those lasted more than 50,000 km.
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
