I declare F-Duct drinking game a success! I am nicely munted, and that was only qualy :)
I am thinking of introducitng a bonus round of some sort for vettel being a tool... details still to be worked out :D
my everything hurts.
Was having a jam session at a friends girlfriends house, in the room we were in theres a pillar that runs across the ceiling and being a tall bastard and all, I have multiplied my hangover by walking into it.
I am thinking of introducitng a bonus round of some sort for vettel being a tool... details still to be worked out :blink:
Drinking game.
Sign me up :(
What job do you have which requires work on a sunday?
I make sure you have water coming out of your tap in a nice controlled way.
Not like that.
Like this.
I made some light progress on my project car, i cleaned the garage, then realised i can't actually do anything i wanted to do this weekend cause i need to get the guards lipped before i can put the coilovers back in. And that the coilovers need new pillowballs and heavier springs. Hopefully will sort that for next weekend thought.
This arvo i started sanding back panels and getting them ready for the primer coat.
Sounds productive. :blush:
Whats a pillowball :happy: ?
sure are, they are my upper shock mounts, also known as Spherical Bearings. I'd really like to get brand new ones but i don't know where to get them from.
In other news, only a couple days until i get awesome pints'o beer and lamb shanks!
Whats a pillowball :blush: ?
I've got two in my pants, if you'd like a demonstration?
So much win! Gonna go for the pork knuckle!
Anyone know/recommend a good detailer on the northside? Mate wants his car done inside and outside before he sells it
Always you know that :blush:
Ask Sabbai.
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
