whos in for german tonight?
i may be. depends on a few doctors appointments this afternoon.
been an eventful fortnight.
what time is it again? at work, and I don't feel like having a photo of hitler saved in my browsing history
but thats half the fun :(
I beleive Anna and i are still in.
Any one had any experience with Varex mufflers? My car is far far too loud, i love it but coming home late at night and rbts ect will be a hassle so im thinking varex could be the answer.
7pm. But you are a member I imagine, so it won't be a problem for you to get in if you're late.
No personal experience with them, but I hate the idea of them.
I dont love the idea, but i hate the idea of my car having to not sound like it does now on a full time basis more.
Dan got abused by some lady today due to its volume so i figure she wont be the only one that hates it
Tony.... that sucks.
Pics of ho's ex? (plus address and work timetable)?
Some SAU loving is in order here methinks..
Your gunna bone his ex too?!?
Dirty Ravbat :(
I was asking for the douchebag ex boyfriends details..... so we can all rock up at his place and deliver some SAU justice...
I'm not THAT much of a ladies man.....
Its meant to be loud.
you'd better use it after I went to all that effort :down:
You'll feel the love man. Just gotta wait for my puda bud to come around and hook me up.
Old man is a veritable 2 fingered typing terrorist on these things. :)
The truth, this man child, he speaks it.
IN!!
Getting closer
Also in.
looks like XXXX man isn't coming tonight, if Kyle doesn't want to come I'll def have to drive as catching the train by myself will be sh*t :(
Dan's a soft cock.
Will def be there tonight. Evening schedule just got cleared :)
Sickness mang :down:
You have to hear it, it isnt just loud, it is literally the loudest skyline i have ever heard, barring ones with a screamer wide open of course
and as per the german club thread I am out, feel like shit, need bed
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
