Morning all!
niceee..
That's what she said
martin, why are you the fearless zombie killer?
Pretty self explanatory: I'm fearless and I kill zombies
Its actually a grab from the game Borderlands, in the zombie expansion pack. Every time the little robot dude calls you on the radio he says "Greetings, Fearless Zombie Killer!"
you a white boiii :P
Whens the last time you saw a black man star in a zombie film?
They don't survive because they hold their gun sideways so can never manage a headshot, and its usually a MAC-10 so they also run out of ammo.
what happened there?
"random" breath test, or more to it?
NFI, that shot was from another state's 31 day cruise.
It's disturbing :huh:
Morning :bunny:;)
Morning. Coming out on Thursday?
fark, where is everyone today?
I have to go to a workshop at milton tomorrow and thursday :bunny:
8:30 - 5:30 days and an extra half hour drive each way ;):huh::P
that really sucks! Though some times i like forced long days like that because it drives my bank time balance up....but if you dont have a bank time system it is fail ++
I'll be able to finish even earlier than normal on friday, but that will be about it
at least you get somthing back in return i guess! Even if it is only small compensation. Found any brakes for project alpha? Whats it weigh and how much power do you predict it will make?
Nope on brakes. There's no great rush at this stage, I'll just keep an eye out for another bargain...
Hoping to get it around 1000kg.
Stock, the GTA engine makes 247HP with a sh*tload of cats and a conservative eco-friendly tune. Hoping with a nice free flowing exhaust and intake and a better tune to see somewhere in the ballpark of 250hp at the wheels.
Transaxles are good for ~350HP at most so stage two (long way down the track) will be aiming for that.
Edited by Smity42
Cool as! should be pretty awesome, R34 GTT brakes might be woth a look at that power and weight!
Sup mangs,
Got up early to go to court for this stupid uni assignment. The court I went to was too full, too many other uni students already in there so now I have to go back again on Thursday. Lame.
In other news. 31 is still going strong booyah.
I really want 4 piston brembos of some description, but yeah might be worth a look if any R34 GTT ones come up for a good price.
Sup mangs,
What you have to do in court?
Skids?
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
