I found an awesome *cough cough* 32 GTR for you guys to haggle over......
Here Tis
Given the interest you have shown in said ghey as aids gtr we will step aside and let you have full dibs on it. :P
Sup mangs. Eventful day so far. 31 wipers refused to work this morning and then for some reason the prick was misfiring too. All fixed now. No idea what happened to the misfire it just went away after it got up to temp. Made me late for my first uni lecture though but ahwell.
definitely sounded like a miss. idling like shit aswell and then when revved died a bit then it was fine. tried revving it again and it was shit between 2-3 grand but then after awhile it sorted itself out.
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
    • Take the fall as a warning sign for future endeavours  Stay safe mate
    • hi mate, HKS cooler piping still available by any chance?
