Not sure on that, Anna doesnt want to eat icecream because she feels bad about missing the gym, but i might come along anyway, especially if Noel goes cause i need to talk to him anyway!
Talks cheap and me being poor i can probably just afford it. Be there about 7
... I'd never seen one in the flesh before the first time I came down and saw the gun metal grey 32. I don't really get out to many car things cause I don't really fit in too well haha.
what's wrong with that? hahah.
I'm on my p's but when I last got it dyno'd it was around 210rwkw, so it's not like its slow for a naturally aspirated car.
Considering coming down just to see this GTR.
And to give Isola some love <3
:laugh:
You drive a Ford
Nuff said
So do you karnt, and I used to! Fords are wicked awesome :(
Edited by Isola
